60 Clutch adjustment
JDMAN60
02-04-2005 04:21:04
I am getting close to the end of my restoration project. Last night I put the belt pulley and the clutch back on the 60 and I can't get it to snap over. while working on it I noticed ( as I expected I would ) that I still have too much end play in my crankshaft ( about 0.041 ). Will this affect the clutch adjustment or am I just not adjusted up enough yet? I ran out off time before I could reset the flywheel, so I will do that over the weekend, but this clutch has me baffled. Thanks for your help JDMAN60
maxwl520
02-04-2005 18:53:49
 Re: 60 Clutch adjustment in reply to JDMAN60, 02-04-2005 04:21:04
Yes you need to set your crankshaft endplay before you adjust the clutch. Once you set the endplay your clutch should adjust fine.
