1938 AR Brake drum
Marty Z
02-03-2005 23:09:48
I have been trying to get the , single left hand side , service brake drum off of the differential shaft . Got a puller on it right now and did use heat. Am I missing some thing ?
Thanks
Marty Z
Marty Z
02-05-2005 07:52:27
 Re: 1938 AR Brake drum in reply to Marty Z, 02-03-2005 23:09:48
OK Guys, Thanks. Tapered shaft is the reason I'm still stuck , and wasn't sure I could take out the whole shaft with the drum still on it. Will try tomorrow. I have used the block of wood method on the first reduction gear and it worked well. Thanks.
Marty
Maark
02-05-2005 10:36:40
 Re: 1938 AR Brake drum in reply to Marty Z, 02-05-2005 07:52:27
Unless that AR has the optional turning brakes, the brake drum on an AR is attached to the lower shaft in the transmission
Dean M.
02-04-2005 17:27:44
Here is a trick from an old John Deere mechanic, Take the whole brake assembly off the tractor, back the nut off til flush with end of the threads, Find a nice thick oak block, put the block on the shop floor and drop the whole assembly onto the block so that the drum is down and it lands on the nut and shaft end. It may take two or three drops from about two feet, but it works every time
Maark
02-04-2005 11:14:04
Marty, that is a tapered spline. You may need to whack the puller on the end with a three pound hammer.
Marty Z
02-05-2005 22:51:21
 Re: 1938 AR Brake drum in reply to Maark, 02-04-2005 11:14:04
Got the brake drum off tonight <>>>>>>
Thanks
MJZ
