1938 AR Rear axel
Marty Z
02-03-2005 23:03:27
When I took off the rear wheels I noticed that the left axel flange is too close to the housing and the right axel flange sticks out about 1 inch more than the left. The right flange has been rubbing on the metal ,felt retainer for some time and has worn down the bolts that hold down the cast iron wheel center . Before I tear into the rear end ,I would like to know if there is a way to even out the axel's . If there are not some spacers or shimms to re locate to even them out I will probably just leave it alone.
Thanks marty Z
Marty Z
02-04-2005 08:33:10
 Re: 1938 AR Rear axel in reply to Marty Z, 02-03-2005 23:03:27
I meant the left axel flange ( not the right one ) has been rubbing and wore the backs of the bolts that hold the wheel center on.
Maark
02-04-2005 11:18:04
 Re: 1938 AR Rear axel in reply to Marty Z, 02-04-2005 08:33:10
Those axles are different lenghts if I remember correctly. May be installed wrong. The parts book shows 2 different part#'s for the rear axle.
Marty Z
02-05-2005 22:55:01
 Re: 1938 AR Rear axel in reply to Maark, 02-04-2005 11:18:04
Got the axels and bull gears out. Still not sure why the left axel is not sticking out enough but will work on it. Thanks
marty Z
Marty Z
02-05-2005 08:20:43
Looks like I'm gonna have to open up the rear end and get those axels out. I looked for part #s on the flange but could find none yet.Probably under the paint. Once I find them it will tell me if they are installed correctly or may be even the wrong axels installed.
Thanks
MJZ
