4010 anti-freeze update
R. John Johnson
02-03-2005 21:01:41
Thanks to everyone for replying. I am going to get some price info on overhaul kits and sit down with the banker. The old girl is a diesel so maybe it is time to look at the injection pump to see if it is causing the white smoke. There is a seal leak on the shaft on the pump where the throttle rod connects, so it should come off anyways. I"ll keep everyone updated
John
JDBert
02-04-2005 06:23:13
 Re: 4010 anti-freeze update in reply to R. John Johnson, 02-03-2005 21:01:41
I'm with bubba on the smoke. Those 389/404 had a tendency to "tulip" the valves and once they did that you lose compression fast.
Mike M
02-04-2005 05:48:17
I overhauled a model 2840 the only reason it was torn down was because of liner pitting,antifreeze was getting in the oil. Got it all back together and it smoked terrible whiteish gray but cleared up when warm.This freaked me out as it ran fine before with very little smoke. I was glad one of my first calls was to my pump rebuilder he said that since I had more compression now it wasn"t burning right and that this model pump can wear inside throwing off the timing. He advised me of which way to move the pump to change the timing (I can"t remember if it was advanced or retarded )and it was the difference between night and day.No smoke and ran great ! I would recommend you have your pump and timing checked out.
Bubba
02-04-2005 03:57:08
I missed your early post but if you are getting white smoke in a diesel, the first thing to do is check compression. That's by far the most common cause.
