Battery cable ? for John T.
JD720
02-03-2005 17:34:25
I am working on a unstyled G puller.I am going to put a Denso gear reduction starter like the one used on the 8000 series tractors.The battery box is mounted out front on the weight bracket which puts it pretty far from the starter.What size cable would be best in this application? Thank you
John T
02-03-2005 18:46:17
 Re: Battery cable ? for John T. in reply to JD720, 02-03-2005 17:34:25
720, Im unfamiliar with that starter HOWEVER, knowing pullers with high compression can be hard to crank (although that reduction gear helps reduce amperage) and due to a relatively long cable run as you mentioned, I WOULD HAVE TO TAKE A GUESS AND RECOMMEND AT LEAST 00 GAUGE CABLES short of getting any specs on that starter, which still leaves unknown cranking torque variables based upon compression.
So long as theres good solid frame member and good solid junctions, a separate ground cable right to the starter probably isnt needed.
If that 00 Cable gets pretty hot when cranking I would increase its size, but I doubt that will happen unless you had to crank it a longgggg ggg timeeeee eeeee e.
THINGS YOU MAY CONSIDER IF YOU HAVENT ALREADY
Are you using a high CCA rated battery (like 1000 or more)????? ,,,,, ,,,Are you using any sort of Generator cutout so youre not wasting HP to charge the battery when pulling???? Have you got rid of horsepower robbers such as fan and water pump, hydraulic loads, etc???? Running high compressions and a high energy ignition????
Best of luck let us know how you do.
John T
JD720
02-03-2005 19:01:03
 Re: Battery cable ? for John T. in reply to John T, 02-03-2005 18:46:17
I will probably run a 1000 cca battery.This tractor is stripped to the bone.I will be running a electric fan and fuel pump,electronic ignition with a MSD box.Hopefully I can get a battery that will supply enough juice for one nights pulling because there will not be a generator.I will just recharge the battery when I get back home.Hopefully I will have it done for the pull at Elnora this September.
Unkown Puller
02-04-2005 18:54:45
 Re: Battery cable ? for John T. in reply to JD720, 02-03-2005 19:01:03
720, I run a big cube, high compression '38G with basically the same set-up on the battery, etc. I use a 1250CCA battery and depending on how many times you start it the battery may not last all night. I use a jump box when it's cool or cold or the first time I start it at the pull. I usually end up useing the jump box before the night's pulling is over. Also depends on the number of classes I pull. There's enough power to run the accessiores, but not enough to start it. JD's are harder to start compared to other brands, especially if you are using a power block that doesn't have petcocks. As I see it they are coming up on compression with 1/4 or 1/6 of their motor and you are at 1/2 with a 2 cyl. It takes a little thinking and work, but it can be done. Good luck and hope this helps.
John T
02-03-2005 19:34:07
Lets try n e mail prior to the Elnora show, I will be there with bells on probably with my B and my Panzer. [email protected] John Nordhoff (812) 824-4608 Bloomington, IN
On that Ignition, if it were mine, I would run a 10 Gauge wire from the starter post or battery to the Ignition Switch and also from it to the coil and distributor.
See you at Elnora I hope
John T
