4020 motor stuck PLEASE HELP
Jonathan Pearcy
02-03-2005 17:33:37
how do you know if a 4020 motor is stuck how can you check it? STARTER DONT WORK
ET
02-04-2005 06:37:12
 Re: 4020 motor stuck PLEASE HELP in reply to Jonathan Pearcy, 02-03-2005 17:33:37
If you can't turn it with a screwdriver in the timming hole as sugested below you should pull the injectors and try again. If coolant or water is in a cylinder it will not turn and towing it or forcing it will bed a connecting rod or worse.
Indydirtfarmer
02-04-2005 05:41:57
 STOP!!!!!!!!!!!!!!!! in reply to Jonathan Pearcy, 02-03-2005 17:33:37
Down the list, someone suggested pulling your 4020 to see if it turned over the engine. If that 4020 is a syncro-range tranny, you can do that. IF IT'S A POWERSHIFT....DO NOT ATTEMT TO PULLSTART IT. Major dollars will flow freely from your bank account....NEVER pull a powershift in gear.
farmerboybill
02-04-2005 05:21:04
Dad saved money for a little while by always parking our 4020 on a slope after the starter fried. Did that all summer one year. 'Course, look at SW Wisconsin on a topographical map. Lotsa hills available.
msb
02-03-2005 19:14:57
Take the timing cover off the right side of the clutch housing and use a large screwdriver in the ring gear to see if it is free.
JD720
02-03-2005 18:47:00
Take the starter off and use a prybar and try to turn the flywheel.If the starter don`t work you are going to have to take it off anyway.
mattd
02-03-2005 18:37:07
put it in a high gear and hook another tractor up to it and see if it can pull it, and if the motor will turn over.
matt
