4240hydraulic
bud hulgan
02-03-2005 16:11:37
hydraulic front end loader slow and 3 point hitch ?
jon-deer
02-03-2005 16:54:04
 Re: 4240hydraulic in reply to bud hulgan, 02-03-2005 16:11:37
change the hydrolic filter first it is located on the left side of trans. case, low and in front of axle. if its still slow check the trans. pump screen it is located behind filter. it takes a 1/2 in. drive breaker bar. when you remove this plug most of your hydrolic oil will come out there is a drain plug on the bottom of the case if you want to drain the oil first. when you pull the screen look in side for foriegn material laying on the bottom of case, if present use a magnet or ? to remove when installing screen avoid letting other end of screen "scoop" up any debris as anything inside of screen goes directly to the trans. pump. if this doesn't help it may be the stroke control valve is sticking. it is located on top of hyd. pump (in front of engine) you will need a special tool for that but is relatively simple.
jon-deer
02-03-2005 16:57:11
 Re: 4240hydraulic in reply to jon-deer, 02-03-2005 16:54:04
i forgot to ask if this 4240 was powershift or quadrange, my reply was for the quadrange.
bud hulgan
02-04-2005 08:05:41
 Re: 4240hydraulic in reply to jon-deer, 02-03-2005 16:57:11
power shift
