GPO steel wheels
GPWT
02-03-2005 09:48:25
I recently picked up a GPO #15093 and will put it on steel. I am pretty sure the rear wheels should be the earlier F&H wheels (C1010R) rather than the later JD made wheels (JD1202R), but the front steel is in question. If I put it on spoke steel rather than cast (either were available) would they have been the late F&H made AC506R (hourglass hub with 3 large weight stop ears) or the later AC651R JD heavy hubs? The tractor build date was 4-9-31. Does anyone have any concrete evidence that can answer this question?
paul o
02-06-2005 19:51:59
 Re: GPO steel wheels in reply to GPWT, 02-03-2005 09:48:25
The parts book shows that only the C2020R front wheel was used on the GPO. There is some evidence elsewhere that spoke wheels were also used. The hour glass hub wheel would be ok, the C2020 would be more appropriate for an orchard tractor.
chooch
02-05-2005 10:15:26
GPWT,
In the Nov./Dec. 1994 issue of Two-cylinder Magazine, the following info was shown regarding front steel on GP's:
Front Wheel / Tractor Serial Nos.
AC167R / 200211-208383
AC439R / 208384-213037 & 213538-213542 AC506R / 213038-216299 & 216800-228109
AC517R / 216300-216799
AC651R / 228100-230745
It does not state the source of the information. Hope this helps.
Chooch
Two-Cylinder
02-04-2005 19:55:11
i do not have the answer to your question but will pose it to a friend of mine tomorrow and let you know what he says. also, i have a pair of the GPO front steel wheels that are the enclosed type. i believe they would also be called orchard front wheels. they are reproduction and are a very nice repro. includes the bearing kit. if interested, let me know.
