Broken carb stem fix?
ToddF
02-03-2005 09:45:21
The main stem that holds the float bowl on is broken off roughly flush with the nut. I have all the pieces. I wonder how to repair it. I have access to machine tools but would appreciate advice on the method of repair. I wonder about making a new stem, but am not sure just how to attach it, or can I put the old pieces back together reliably? Thanks in advance.
ToddF
02-04-2005 08:36:49
 Re: Broken carb stem fix? in reply to ToddF, 02-03-2005 09:45:21
Thanks for all the advice. It is off a '47 A and apparently it froze and broke at some point. Robert's estimated about $150 to repair and rebuild. I own a lathe and have a couple old spark plugs, so I think I'll attempt that fix myself. Thanks again for all the advice.
CRUSADER
02-03-2005 21:51:52
Todd, What model JD is it? There is a guy in Nebraska that sells a repair screw for it? You will need to machine it down flat, tap it and then screw the plug into it. I have a carb for a 630 that has the same problem. This repair part won't work on it due to the fact that it is a DLTX and the set up is a little different. Have talked with a couple of people that have used this repair and it worked like new. To have the DLTX rebuilt/repaired will be costing me around $250 plus shipping for the cheapest quote. Still trying to make myself let go of the cash to do it.
later days mate,
Jim
ChuckW
02-03-2005 11:34:48
As I recall, the threads on hydaulic fitting is the same type. I'm sure the spark plug would be less expensive. I used brass to get a stronger weld.
old
02-03-2005 11:00:16
Fixed one for a B once by brazeing a piece of pipe to it and then used a pipe plug to hold it on. Clooneys idea seems better but either will work, till you let water freeze in the carb and you have to start over again or as I had to do buy a new/rebuild carb, $500 ouch
J Clooney
02-03-2005 10:32:49
Todd, your best bet is to throw the broken parts in the trash can,, then take a spark plug & cut the bottom off so you have a flat surface,, then silver solder that to the bottom of the stem.. You will also need to file or face the bottom of the stem off flat� Be sure you leave clearance for the brass load nozzle & spring to fit back in correctly.
Years ago I repaired a few like the above.. Now I just put the cut off spark plug base in my lathe & machine it to have a step on it�s OD.. Then put the carb in the mill & face the stem off flat then counter bore it to accept the step on the plug base.. That gives a perfectly centered fit & also gives a better silver solder connection.. As long as the bowl nut isn�t over-torqued they hold up fine..
Clooney
Duane Larson
02-04-2005 08:26:24
 Re: Broken carb stem fix? in reply to J Clooney, 02-03-2005 10:32:49
ToddF,
To add a bit to Clooney's fine advice, use the threaded part from a Champion W18 as the ID of the threaded base is very close to the ID of the carburetor neck. If you use a 7/8-18 plug base with too thick a wall the ID can be too small to allow the nozzle to fit through it, then you have to do some additional drilling.
JDBert
02-03-2005 10:19:19
I had Roberts carb do a unstyled "B" carb a couple of years ago. I think it was something like $175, but worth every penney. You couldn't even tell it was done. He has a jig set up and cuts the entire stem off, machines it all square and then reattaches a new stem.
will in Tx./Mn./ USA
02-03-2005 14:58:48
 Re: Broken carb stem fix? in reply to JDBert, 02-03-2005 10:19:19
$175.00 >>> that's way too much!
They must of seen you commi'n
~Will
Pat Browning
02-03-2005 11:26:35
Going to Robert's Carb for this repair is an excellent idea. The carburetor is no place to experiment. Just go to robertscarbrepair-dot-com for point of contact. I can assure you that satifaction will come to you! 'Fine folks up there. (PatB)
