'51 B shutter control rods
Kurt_JDB
02-03-2005 04:45:03
I have recently located a good set of shutters for my "51 B. I have not been able to locate the two rods that connect the shutter to the control arm. Would anyone have any dimensions for these rods, or would anyone be willing to send me a tracing of the rods from which I could fabricate a set?
Thanks,
Kurt
Bob Collins
02-05-2005 17:37:24
 Re: '51 B shutter control rods in reply to Kurt_JDB, 02-03-2005 04:45:03
Kurt, I searched around my shop and found an extra one I bought at a junkyard when I needed one for my '51 B, it is the back(longer) one and measurers 52 1/2" long. One end has a 90 degree bend 5/8" from the end with a cotter pin hole drilled near the end. The other end is threaded 1/4-20 it is 1/4" rod stock. On the threaded end is an adjustable 90 degree "elbow" to allow making precise adjustment so it will line up with the hole in the shutter control arm on the steering post. Mine is bent up some but I think it is nearly straight when new. I don't have the front rod available to measure but it should be easy to estimate after the rear one is in place. Regardless what others may say, I favor having and using shutters even on gas tractors to keep engine temp high enough to keep the fuel atomized in the manifold and reduce oil contamination.
Kurt_JDB
02-05-2005 20:46:04
 Re: '51 B shutter control rods in reply to Bob Collins, 02-05-2005 17:37:24
Thanks for the info. I use the tractor lightly and have never really been able to get it over 170 degrees. I also think it is important run an engine hot enough to boil off the H2O and other bad stuff. Besides, having an extra control to mess with just adds to the fun.
Regards,
Kurt
ChuckW
02-03-2005 04:52:01
The rods are typical round stock. There is a bracket at the shutter screen. You could set the control arm to stop and make your own lenght, adding the end adjusters. I don't think there is a factory measurement anywhere. These shutters are good for factory restoration but are totaly and I mean totaly worthless on a gas model, as a matter of fact will make it overheat. That's why most were removed. Would be nice and probably a necessity on an all fuel.
