I believe JD put in three O-rings and the weep holes so that the leak from the water jacketed part of the sleeves would be diverted out the weep holes instead of into the crankcase. That presumes that the lower O-ring isn't worn or rotted to leaking too. Some suggest plugging the weep holes, to stop the visible leak. But that means when the bottom O-rings fail that the bearings are going to be eaten by antifreeze which isn't a good idea. In the last run of 4020 (beginning in 1968) the blocks didn't have weep holes. They also didn't have the forced ventilation pump for the crankcase. Replacing the sleeves shouldn't cost more than gaskets and O-rings (if not in the gasket set) for parts. Essentially pull the head, then the pan and the rods and pistons. Check for wear, then pull the sleeves. Clean the O-ring places and put it back together. While you have the rods loose from the crankshaft check the crankshaft for wear, and the rod bearings for clearance. Its easy, and not expensive, at that point to slip in new rod bearings. Unless the pistons and sleeves are worn badly, you can figure the failure of the O-rings is from old age. While its apart, pistons, rings, and sleeves run $600 to $1000 for parts. Labor just a hair more than putting the old ones back. A fueling problem could easily be plastic parts in the Roosa pump failing from old age. I read reports of that all the time for 4020 diesel. White in the exhaust of a gas engine isn't a fuel problem, its coolant. In a diesel it can be fuel. When you are hurting for money, fixing only what is broken without massive improvements is more profitable in the short run, more costly in the long run. Gerald J.
