FFA student needs help on john deere b
dexter
02-02-2005 16:55:33
we have a 1948 john deere b we rebuilt it and went through everything on it. we set the valves at .020 and the tractor at an idel still misses on the flywheel side. i think that it might be the plug wire but not forshure??? can use any help given!!!!! !!!!! 1
Will P
02-03-2005 14:51:17
 Re: FFA student needs help on john deere b in reply to dexter, 02-02-2005 16:55:33
Are your plug wires metal core? Don"t use carbon core wires like those on a car. Don"t use Champion plugs. Some people will respond to that last statement. Run Autolite 388 plugs.
The flywheel side will usually hit all the time. The pulley side will hit about 40% of the time at idle. Put under load, it will be fine.
Will P
43A
43B
49G
51G
jd b puller
02-05-2005 15:14:33
 Re: FFA student needs help on john deere b in reply to Will P, 02-03-2005 14:51:17
I have had really good luck with AC 88 plugs. They are a lot hotter than the Autolite386. Napa usually carries them or can order them. Get the AC87 if they don"t have the 88
Bob
02-03-2005 08:26:17
Congratulations, Dexter! You've discovered the "Johnny Popper sound" that gives these old machines their character!
Don't try to fix it, as that is what it's supposed to do!
mattd
02-02-2005 17:33:11
this is my theory, which i made from info on this site. because of the 540/180 firing times it may sound like it is firing on one cylinder but it firing on both, because the the #1 cylindar exhaust has to go farther and #2 fires right after it makes it sound like that. and because of the single carb 2 cylinder setup one cylinder gets more fuel than the other, the right #2. 1 is still firing, its just weak. one way to find out is to hook it to a plow, disk, whatever and make it work at full throttle. it should sound like its firing on both cylinders.
HTH
matt
dexter
02-02-2005 18:51:29
 Re: FFA student needs help on john deere b in reply to mattd, 02-02-2005 17:33:11
i ckno that it fires on both during a load but when its ideling i can pull that pulg wire off and it makes no difference on how it is running so it does haveta miss on that one right????
mattd
02-02-2005 19:19:21
 Re: FFA student needs help on john deere b in reply to dexter, 02-02-2005 18:51:29
yes it is missing then. because of the single carb thing. this is why deere went to dual carb setup. if you pull #1 plug wire it'll probably sound the same. pull #2 and it'll pry sound different, worse probably. but #1 will start to take more fuel and it'll still run. switch your plugs and see if it makes a difference. i dont remember gap off the top of my head. and double check valve tappet gap. one valve may be opening more/less than the other. HTH
matt
