Grinding noise from crank on 720D...
Mark
10-24-2003 08:52:09
On a JD 720 D standard...was pulling 2 full wagons of soybeans to the elevator. I had the tractor running for 1 hour prior to the 4 mile haul, then when I got to the elevator, I shifted down to 2nd gear from 6th and a loud noise, almost a constant grinding or howling noise came from the flywheel area�.(didint check to see if it was lounder on the clutch side) i don�t think it was a tranny noise�it was there even when in neutral, with the clutch forward, backward, or in gear, I quickly turned it off.
45 minutes later, I started it back up and it didn�t make the noise anymore??? The tractor flywheel was off when I bought the tractor and the clutch was apart�.it was put back together and with new clutch parts including the friction disks and drive disk�the noise was almost like someone was holding a bar of steel onto a brake turning brake drum cover�but it was much, much louder and deeper grind or howl�.my first suspicion was that the endplay in the flywheel/crank was excessive as it appears to have a lot of play�side to side�so the tractor was running for almost 1 � hours before it made the noise and then it was off for 45 minutes and when started back up it was OK? This is a 720 Diesel Standard model.
Any thoughts on when this might be? Thanks for your help!
