JD 3020 - newbie questions
Tip
02-02-2005 10:18:17
I have an opportunity to pick up a clean 3020 gas with new rubber and nice sheet metal. It has a loader, dual remotes and dual PTOs. Runs good, no smoke. The seller is asking $6.5k for the machine.
I am going to use the tractor to pull a NH275 baler and wagon on some hilly terrain. Opinions welcome on the tractor, proposed price and what I should be careful of. I have lots of experience with Ford tractors, not any with JDs.
Tip
Tip
02-03-2005 04:33:46
 Re: JD 3020 - newbie questions in reply to Tip, 02-02-2005 10:18:17
Thanks guys. The tractor does have a wide front. The loader was added by a friend of mine and only used by the gentlemen farmer who owned the tractor for a couple of years - I'm sure he didn't do enough to really wear much.
The tractor is getting a new carb and then I am going to run it around a bit.
I'll keep ya posted.
Tip
dkraj
02-02-2005 19:44:05
We have a 2520 that pulled a 310 and wagon in hilly-toooo hilly in places, for years. Our massey 1100 plays with the same setup nowadays but the 2520 did it well for years though. 3020 should be a bit better.
pbutler
02-02-2005 17:41:04
Didn't say if widefront or not, assuming not since has a loader-if not be very very careful on that hilly ground.
Good price for that tractor. Loader work can be very hard on a tractor-especially transmission, front end, and clutch-so I would run through the gears and make sure they all work properly. Look the front end over.
If all looks good you may have found a nice buy.
msb
02-02-2005 11:07:53
If the loader is include and is in reasonably good condition,I think the price is not out of line,especially in today's market.I think you will simply love the 3020 on a baler.The only thing better would be a 3020 Diesel.
