4430 muffler
charlesmm
02-02-2005 00:39:52
My 4430 is significantly louder than my 4230 so I looked down the exhaust and noticed that half way up the muffler there is the corroded remains of what appears to have been a plate , which would have had the effect of forcing the gasses through the large number small holes that run the full length of the muffler. Could someone look inside their exhaust and tell me if this plate should have some holes in it ,or do all the gasses get forced through the little holes ? Also any ideas on what to block it with , obviously the turbo needs to breathe and something which dropped down and into the blades would be a DISASTER
I must admit that the snarl that she makes under load when you open the door is better than anything Mozart coyuld have composed, but I would still like to listen to the radio occasionally
Tim A.
02-02-2005 20:20:29
 Re: 4430 muffler in reply to charlesmm, 02-02-2005 00:39:52
I recently put a new muffler on my 4430, replaced the straight pipe that was poorly welded to the flange clamp (that way when I bought it). Can't help you with what it looks like inside as I did not look. The replacement ones from JD are not flared at the bottom and do not attach with a flange clamp like the original. They have a flat clamp and just slide over the top end of the exhaust manifold. If the top portion of your manifold is a bit deteriorated from heat/age, you might have buy a piece of flanged pipe and cut off the flange and weld it to the bottom of your muffler. Before you buy a new one from JD (like I did), if you have an Atwoods or TSC nearby, you might check there. I was in Atwoods after I had already replaced my muffler and they carry replacements (or have them listed in a book by the mufflers)for it seems like all the older tractors. They had one hanging there that looked identical to the JD one for about $54...just a little over half of JDs price.
Hope this helps.
Tim
Johs in Indiana
02-02-2005 14:42:01
Charles, according to the deer parts catalog on the internet that muffler indeed has a plate in the center of it. Im no expert but i would have to say that yes, it is used to direct the gasses into the rest of the muffler. If you have a good cap on it or a curved stack I wouldnt worry about it too much. Deere has them for around $90 i believe. Hopefully someone else will jump in that knows a little more than me and help us both out.
Good luck,
Josh in Indiana
