Brad B 3010 rockshaft
msb
02-01-2005 20:40:21
Brad What is your tractor serial number?
BradB
02-02-2005 04:36:54
 Re: Brad B 3010 rockshaft in reply to msb, 02-01-2005 20:40:21
My serial # is 11T16686
HTR
02-01-2005 22:02:51
Bob, I don't know what his serial no. is, but the first year tractors didn't have the thermal relief valve. The cover with the valve was an up date, and should have been added later, but some just didn't get done. Same with the selective control valve. The cover with the thermal relief valve was a recall program.
Just thinking, we sold thirteen 3010 4010s (all we could get) in the fall of 1960. That was about $65,000 worth of tractors, big money. Did you do any of the steering valve up dates? After thirteen in a row, I understood the new steering system.
msb
02-02-2005 11:02:56
 Re: Brad B 3010 rockshaft in reply to HTR, 02-01-2005 22:02:51
Obviously your tractor was not updated Brad since your serial number falls below the break of 32,400.
No HTR, I didn't get in on the 10 series update other than boring the holes out to 5/8" (I believe) in the clutch pressure plates so the clutches would not be so hard to operate. I attended a 30 day service managers training program in 1964.We had to go through each and all components of the 20 series(& 10 series steering valve since it was different) and trace the oil flow through each hydraulic function.We had a cut away of everything including a complete tractor.It was great training and believe me we got to know the 20 series and the 1010 & 2010 up close and personal.There were 4 of us here in Indiana and 1 from Kentucky that took the course. O.K. Brad.Back to your problem.First set the L&D in D(next to your right heel as you sit in the seat).Push the lever all the way to the top withe engine running.Then see if the arms have completely raised, by trying to lift them.A little movement is acceptable due to normal wear.If not, then adjust the control cable at the the lever on the control valve to where the arms are completely raised.BE CAREFUL! Shut the negine off before making the adjustment to the cable length.
Next place the L&D in L.With the engine running and the arms down,very slowly push the lever forward until the arms just begin to raise.Then note where the front edge of the lever is in relation to the numbers on the decal.Push the lever all the way against the dash and let it set there for a few seconds.Then slowly lower the lever until the arms begin to drop.Note the number that lines up with the front edge of the lever.You might have to do this 3 or 4 times to get an accurate read. Ideally the raise point should be at 1 and the drop point should be at 4 if the valve is propery adjusted.If this is very far off then remove the bung hole plug in the rear of the differential housing and slightly to the right of the center of the tractor.Next very securely tape a 9/16" socket to a long extension or extensions.3/8" sockets and extensions work best for this.I welded a socket to a rod years ago for this purpose,because if the socket falls off,You will have a serious problem.Take a light and look in the hole for a castellated nut with a rollpin through it to see what you are working with.With the engine running and the L&D lever set in L and the leading edge of the operating lever set on 1, go in with the socket and push the nut back to disenagage the rollpin.(Once again-BE CAREFUL)Slowly turn the nut counterclockwise until the arms just begin to raise.Release the nut into the nearest slot on the nut.The recheck the raise and drop points.If they are correct the adjustemnt is completed.Hopefully this will cure your problem.Good luck,bob
BradB
02-02-2005 14:20:51
 Re: Brad B 3010 rockshaft in reply to msb, 02-02-2005 11:02:56
Bob,
Ok, Great I had to get tractor out of the shop for another project. I will print this and give it a try soon. Thank you for all the help. This board is really great for getting help with problems from the guys who have been there and done it.
