60 crankshaft splines
Bobby's toy
02-01-2005 17:55:19
On my 60 jd the splines seem to be worn down due to a loose drive disk before i got it. I have put a new drive disk on but it still is loose. it apeares to be a tapered spline is there a prosedure to repair this or is the crank shot.
GRDINMD
02-02-2005 18:53:13
 Re: 60 crankshaft splines in reply to Bobby's toy, 02-01-2005 17:55:19
Theres a crank shop in Easton Maryland Moreland Crankshaft. He Rebuilds and fixes those cranks at a reasonable rate. Cant say im sold on the undersizes, seems to me that they always wear the discs funny and have some shimmy. For what its worth. GRD
Bobby's toy
02-01-2005 19:00:57
Thank's for the info. I'll give Denglers a call. If that don't work out i'll pull the shaft and have it machined. Thanks again bobby.
Clooney
02-01-2005 18:30:06
Bobby, those crankshaft splines are very hard to repair without pulling the crankshaft & having it welded up & re-ground.. Depending on how much spline damage you have you could try calling Dengler Tractor 1-513-423-4000� They have (had anyhow) under sized spline clutch drivers to fit those worn crank splines..
Clooney
Don c
02-02-2005 03:49:51
 Re: 60 crankshaft splines in reply to Clooney , 02-01-2005 18:30:06
Bobby, I got one from Denglers a couple years ago. I called them and they asked what it looked like, told them what was a tad bit loose, I got the 30 thousand undersized and I also got the floating disk as a matched set. Have not had a problem since. Don c
Walt in Jaxn Tn.
02-01-2005 18:28:33
Friend of mine had his son weld up the splines with a wire welder along the areas that were worn, remember to not place the ground clamp on a surface that has a bearing run on it, also don't build up a lot more than you intend ot grind away. Then his son used a small hand held air grinder and eyeballed the splines as he cut away the weld till it looked like it ought to look and it worked perfectly. This was on a early unstyled "B". I personally think they just got lucky!!!! --Walt--
John T
02-01-2005 18:27:14
Bobby, they manufacture undersized drive discs to allow for worn crank splines for some tractors, not sure of the 60??? Seems like Denglers may sell them???
If worse comes to worse and you wanna spend the bucks, its possible for a machine shop to rebuild the splines, of course.
Other home spun redneck fixes I have seen (Im NOT admittin to nuttin here lol) involve the cutting of thin steel shim wedges and inserting them into the base of splines and gettign a good tight fit which requires an impact wrench to milk the disc back in near but a tad less than flush with the cranks end for a good tight fit??
Or, if youre good with a wire welder n have patience n skill, you might fill n weld up then file down some in the splined area n see what happens??? Worse is it could come loose agian or you trash the crank so bad it takes a machine shop to rebuild it or you get a new or used crank maybe??? Got a lot of bucks to spare n how much time skill n patience you have will determine the answer in case an undersized disk isnt available I reckon.
Let us know, good luck n God Bless
PS get it back in time on the correct splines to avoid vibration you know !!!!! !!
John T
