Linwood, the place I start my initial rough in adjustments are closed down full then back out approx. 3/4 to 1 1/4 on the Load Needle and around 2 out on the Idle Needle, then work from there. The best n only true way to then adjust the load needle is under load, maybe via a Baker Fan on the clutch pulley or a good load like a feed grinder etc on the PTO. However, if you have no load, you can rough in set her wide open and open out (richen) the load needle till she starts to black smoke n run over rich, then just back it in a tad leaner till she stops. However, when setting them by ear or feel, Ive found its easy to have them too lean if shes under a heavy load, so at no load n wide open, maybe set her out till she black smokes just a tad. On the Idle, I set her to a good slow idle where the horizontal stop screw is bumping up against the vertical stop spring, then lean her in till she starts to die, then open her back out just a tad richer. I set the floats sort of by feel n look so she shuts the gas off when shes at approximately LEVEL. Seems like the spec is around 3/8 or so from the top of the float bowl, but I have no specs or data handy. This is one of those questions where its fun to see the different methods other gents use n what works for them and each tractor can be a lil diferent as theres many variables. Good topic, good luck n God Bless John T
