60 JD Shifter problem?
JEFF JENKINS
01-31-2005 21:49:52
HI THERE
HAVE 60 THAT I WAS GOING TO USE THE OTHER DAY AND IT WAS COLD. I WAS MOVING SHIFTER AROUND TO MAKE SURE IN NEUTRAL AND SEEING HOW STIFF. ALL OF A SUDDEN THE SHIFTER KIND OF POPED UP AND NOW IS ABOUT 3/4 TO 1 IN ABOVE THE WEAR GROOVE. I BELIEVE THE SNAP RING ON OTHER SIDE CAME OFF. WILL IT STILL SHIFT IF I REMOVE OTHER SNAP RING AND SPRING AND SEE IF IT WILL GO DOWN OR WHAT???
J Clooney
02-01-2005 03:06:33
 Re: 60 JD Shifter problem? in reply to JEFF JENKINS, 01-31-2005 21:49:52
Jeff, it sure sounds like the snap ring has popped out of the lower groove & allowed the lever to come up through the fulcrum ball.. You might be able to shift it a little by holding the shift lever at the correct height with one hand while shifting with the other hand, but the only real cure is to pull the trans top cover & reinstall the snap ring in the groove-- or better yet, installing new snap rings.. I usually trash the originals & use double thinner automotive type snap rings as they seem to hold much better than those old Deere types..
Clooney
JEFF JENKINS
02-01-2005 21:52:06
 Re: 60 JD Shifter problem? in reply to J Clooney, 02-01-2005 03:06:33
THANKS FOR THE RESPONSE.
