Hard starting 4020 propane
matthies
01-31-2005 20:55:55
Just to let you guys know what I was overlooking. This tractor would always start cold, never warm, even if it ran less than a minute. I fixed all the hydralic problems with no luck, then tried a bigger starter, two batteries, and even a destroker. This tractor even had electronic ignition and still nothing. Yesterday I pulled plug wires off of the cap while it was running and noticed a weak spark. Installed a new coil and its a different tractor, this tractor ran fine when you had it running even drove it 18 miles to my shop, up and down hills with good power. So just because it runs good otherwise doesn't mean the coil is good. Other mechanics said either coils work or they don't. Maybe I'm the first one to find this. I was debating this idea awhile back, guess I should have done it. This tractor started tonite with a converted diesel starter at 35 degrees, then I put the original starter, one battery, and it was warmed up, still starts. Wasn't plugged in either. Things are looking up, better buy a lotto ticket now.
jdemaris
02-01-2005 06:36:47
 Re: Hard starting 4020 propane in reply to matthies, 01-31-2005 20:55:55
Just curious, what coil did you put on it? I've had similar problems with later gas engine Deeres when the wrong coils were installed. They'd run fine but not start well when very cold. Deere calls for a 6 volt coil on that tractor. Is that what you used?
matthies
02-01-2005 20:34:52
 Re: Hard starting 4020 propane in reply to jdemaris, 02-01-2005 06:36:47
Yes I bought the 6 volt right from Deere. This tractor wouldn't start after it ran 30 seconds or 30 minutes. The one I replaced looked original, had the Delco Remy on the top and a 111---- part number on the side. This tractor started right up this morning without a heater and at 32 degrees. chris
