1020 crakshaft endplay
deereford
01-31-2005 20:26:52
My 1020 measures .028" end play and the crankshaft thrust surface is scored. Is there any supplier of oversize thrust main bearings to be purchased and installed after the crank thrust surfaces have been machined? Your response will be greatly appreciated. Thank you very much in advance!! deereford
jdemaris
01-31-2005 20:39:38
 Re: 1020 crakshaft endplay in reply to deereford, 01-31-2005 20:26:52
They were commonly available when I did my 300 (same as your 1020 - just yellow instead of green). The bearings weren't available with just the oversize thrust per s�, but came as a complete undersize bearing. I forget exactly how much oversize the thrust was, but I assume it was .020 over since the journal size was .020 under.
