3-brush generator question
mike
02-15-2004 14:35:01
Anybody know where the field wire goes to?
Clooney
02-16-2004 13:26:52
 Re: 3-brush generator question in reply to mike, 02-15-2004 14:35:01
third party image
Mike, this picture should help explain the proper wiring [if you have the light switch controlled field circuit]..
~If you have a 3 or 4 wire voltage regulator instead of the light switch field control as I posted below.. Just E-Mail me for a wiring schematic for that..
[email protected]
John T (Switch Pic)
02-15-2004 21:06:41
Mike, the web site below has those combination Lights/Field Control Switches for use on many 3 brush generators and they used to have a full color picture to compare with what you may or may not have on your dash board. Thats where the Field post on the Generator is externally wired to IF YOU HAVE THAT (cut out relay and light switch field controller) VERSUS A 3 OR 4 WIRE VOLTAGE REGULATOR. As I told you below, thats where the Generators Field windings get their external ground connection on most 3 brush generators, with their internal connections being as I already described for you. However, Ive had 3 brush generators that still used voltage regulators, though most 3 brushers used the light switch for their external field ground.
Let us know how you come out or if you still need that wirign pic I mentioned
John T [email protected]
Link
Clooney
02-15-2004 16:17:53
Mike, that depends on the type of 3 brush generator you are working with...
~If you have a non external field controlled generator [only one post on the generator case] one end of the field winding goes to the movable 3rd brush & the other end of the field winding goes to a generator case ground inside the generator...
~Now if you have a 2 post [A & F] externally field controlled generator, one end of the field winding goes to the 3rd movable brush & the other end hooks to the [F] post sticking through the generator case..
~Now to probably answer the question you asked [assuming a 3 brush Delco generator on a Deere]....The field wire running from the generator's [F] post could run to 1 of 2 places depending on the tractor & application..
~On most of the older Deere 3 brush tractors the Field wire runs to the [F] terminal on the light switch where it then runs to ground through a resistor in the light switch [that's low charge] ,, Then when the lights are turned on, directly to ground [that's high charge]..
~On some of the later 3 brush generators [or early ones that have been converted to a voltage regulator] that field wire hooks to the [F] terminal on the voltage regulator [if it has a voltage regulator]..
~The way to tell... If it has a 2 terminal [small oblong cover] cut-out relay the field wire hooks to the light switch's [F] terminal.. If it has a 3 or 4 terminal [square cover] voltage regulator the field wire hooks to the [F] terminal on the regulator..
Any questions just post back or E-Mail....
[email protected]
John T
02-15-2004 15:45:11
Mike, on a 3 Brush Generator, the not to the Field Post end of the 2 series Field windings goes to one brush there on the side and close to another brush which is wired up to the Generators Armature (larger of the 2) post.
The other end of the Field windings (the 2 fields in series) is connected to the Generators Field (smaller of the 2) Post and it gets its ground via a Voltage Regulator or most often via a dual purpose combination lights/field control switch up on the dash. The brush off on the other side all by itslef is the grounded brush. The closer those two non grounded brushes are moved together (loosen a screw and rotate plate) the higher the rate of charge.
Post back or e mail me if you want me to e mail you an internal wirign pic of what I described above, but its pretty simple actually. Field to a brush next to the other brush wired to the ARM post, other end of the 2 fields in series is wired to the Gens external Field post.
Good Luck n God Bless [email protected]
John T Nordhoff
