1937 John Deere B
Courtland
01-31-2005 10:34:08
Head question...what am I looking at?
After pulling the spark plugs, I can see the left side piston @ TDC with the addition to what may be a "shelf" or "step" 1/4 the size of the piston?
I'm not sure.
Also after looking at the valves only one will spin when grabbed by hand? Are they supposed to spin?
greenmech
01-31-2005 18:07:49
 Re: 1937 John Deere B in reply to Courtland, 01-31-2005 10:34:08
Is the step on the piston? If so you may have a high compresson piston. Or a cylinder insert to raise compression. The valves may not spin by hand if they are closed. I wouldn't worry as long as they open and close. Ron Mn.
step is in the cylinder-C
02-01-2005 06:42:57
 Re: 1937 John Deere B in reply to greenmech, 01-31-2005 18:07:49
greenmech
02-01-2005 15:11:04
 Re: 1937 John Deere B in reply to step is in the cylinder-C, 02-01-2005 06:42:57
You must have a cylinder insert to raise compression. By the way how does she run? Ron Mn
Courtland
02-02-2005 06:27:36
 Re: 1937 John Deere B in reply to greenmech, 02-01-2005 15:11:04
she is not running yet. too many parts left to obtain from the previous owner. Carb,mag etc...
thanks for your help
