Alt update
Jack
10-24-2003 08:43:16
Thanks for your replies folks.I unhooked the battery and took the test light to the cable and the battery and it lit up.While lit I unplugged one of the little wires on the side of the alternator and the light went off.So,I ran two wires from a switch to the alternator so when I don't drive it I can manually keep it from draining the battery.It charges very well.Thanks.
Wayne in Tn.
10-24-2003 10:44:54
 Re: Alt update in reply to Jack, 10-24-2003 08:43:16
Jack, if you are using a flip switch to (excite) the altenator, you can use a push button type switch instead, then you don't have to remember to flip it off when you kill the engine. All you have to do is, punch it once after starting the engine, then forget it.....
John T (Wayne n Jack)
10-24-2003 13:02:59
 Re: Re: Alt update in reply to Wayne in Tn., 10-24-2003 10:44:54
I wasnt quite sure which lil side terminal wire you unplug making the lite go off??? Sounds like you used the 1R??? The lil 2F should be jumped permanent right to the alternators big main output, while the lil 1R side terminal could/should be fed from a SWITCHED source like the ignition switch (hot ONLY when igniiton on) and a series 10 ohm resistor and perhaps a diode if necessary. ANYWAY, if its the lil 1R and its fed from a switched source (like ignition switch output) when that is OFF the circuit floats and is not connected to the battery and shouldnt be able to provide a current drain discharging the battery. However, if your lil 1R is wired so its ALWAYS hot and that terminal DOES PROVIDE a ground path somehow via the alternator????? ?? then I see how it could discharge. If the discharge isnt via the alternator at all, then you may still have a minor discharge problem looming.
If you switched the big main output that is usually wired to the ammeters load (non battery) side, that should be a 10 gauge wire and a current rated switch, but you referred to the side terminal which would be 1R or 2F.
Anyway, if it works and suits you dont fix it I guess but any source to the lil 1R shouild still include a series 10 ohm resistor.
Good Luck Yall, were headed to Ball State for a family weekend visiting my favorite daughter, see ya Monday.
John T
Jack
10-24-2003 13:45:06
 Re: Re: Re: Alt update in reply to John T (Wayne n Jack), 10-24-2003 13:02:59
The 2F is what I switched,once I did that my discharging problem stopped.2F goes to the big post on the back side of the alternator(through my new switch).I used a lighted switch and mounted it right on the dash in front of me and right next to the ignition switch to where I had to look at it every time I started it and cut it off.Thanks fellas,Jack(TN).
