49 A magneto
rwhde
01-31-2005 09:35:00
Can I put a distributor on my 49 A and if so what would I have to change beside the magneto itself? I currently have it running but the coil inside the mag. is dead and I have put on an external coil and I would just as soon go ahead and rerplace it with something else.
rwhde
02-01-2005 09:27:28
 Re: 49 A magneto in reply to rwhde, 01-31-2005 09:35:00
I didnt figure to stir everyone up with this one. But he was correct, just drill through the face of the mag. housing and run in with a coil wire from the external coil. My 51 has a plain old point distributor with an external coil. Can I put one hust like it on my 49? It makes more sense to me to have them both the same.
1945 A
01-31-2005 14:31:21
I'm thoroughly confused!
How were you able to connect an EXTERNAL coil to your mag and get it to run?
I'm not trying to be a smart a**, I've thought this over and don't understand how you'd ever get it to work....
Lee B
02-01-2005 02:33:04
 Re: 49 A magneto in reply to 1945 A, 01-31-2005 14:31:21
I'm just guessing here but it would appear that he has a WicoX distributor with internal coil that went bad, but wants to call it a magneto because it looks like one, but it's not. If that doesn't straighten it out some for you, let's both quit because I'm way past the point of knowing what I'm actually talking about.
buckeye al
01-31-2005 14:50:56
Basically the mag's points & condenser are used just like a distributor's points & condenser to operate a battery ignition system type coil. Pretty easy with a type C mag, not so easy if using an X type. Only saw it once on an X. Guy removed the mag coil, drilled a hole through the side of the distributor cap, ran both wires through the hole twisting the HV coil wire around the long leaf spring to get the spark voltage to the distributor rotor button. Rain, dust & crud were chronic problems but as long as it was clean and dry, it worked.
John T
01-31-2005 11:57:08
RW, YES indeed you can easily convert that Magneto equipped tractor over to a battery powered coil n distributor ignition, assuming you have a good battery n charging system to operate it. Here's what you need,,,, followed by how to connect it,,,,, and rough in its static start timing.
1) You will need EQUIPMENT
a) A Delco Distributor (I recommend that over the Wico XB),,,,, ,,,,
b) EITHER a full 12 volt rated (internally ballasted) coil OR else a 6 volt coil and a series external bathtub type ceramic Ballast Resistor, if your tractor is 12 volts and you go with the 6 volt coil. NOTE if shes 6 volts, then you simply need a 6 volt coil and no ballast,,,,, ,,,
c) Some sort of dash mounted ON/OFF Ignition Switch, be it key operated, or Toggle type, or Push/Pull, and at a minimum a SPST (On and Off) 2 contact(s) switch.
WIRING
2) Run a feed wire (16 Gauge will work fine) FROM the load (NOT to battery) side of your ammeter (if it has a working one, or else another live voltage source) or off the LOAD terminal on the Voltage Regulagtor if you happened to have a 4 wire (BAT ARM FLD LOAD) Voltage Regulator, over to the Ignition switches BAT input terminal,,,,, ,,,,, ,,Then run a wire from the switches IGN output terminal (which is HOT when ON) down to the coils high input (NOT to distributor) terminal or through the series ballast in the event your tractors 12 volts and you use a 6 volt coil,,,,, ,,,,, and run the last wire from the coils low (NOT from switch) side terminal to the distributors terminal.
START TIMING
Then wire her up and time the distributor and youre good to go. BASIC THEORY The distributors points need to first break OPEN on the leading cam lobe when the left piston is at TDC on its Compression Power Stroke and its rotor tip is lined up with the leading cap tower to the LEFT cylinder,,,,, and then 180 degrees of flywheel/crank rotation later,,,,, ,,the points again break open on the lagging cam lobe and the rotor tip is lined up with the lagging cap tower to the RIGHT cylinder.
a) If you FIRST had the distributor installed but bolts loose and it rotated max forward CW retarted, and stopped the flywheel where the left piston at its TDC (thats when the flywheels Left Hand Impulse timing mark is at 3 o clock in line witH a flat mark on tractors side) and had the ignition on and the left plug wired correct with its wire attached and side grounded to observe a spark (or just use the bare wire end to 1/8 inch from tractor steel),,,,, ,,,,, ,,,,, ,,,,, ,,,,, ,,,,, ,,,,, ,then slowlyyyyy yyyyy advance the distributors timing by rotating it back CCW till she sparks,,,,, ,,,thats close.
b) To accurately tell where shes firing at at RPM and observe the advance functioning, you would have to use a timing light, but the above will get your initial rough in static start timing going..
SUMMARY, Again basically, you rotate the distributor forward CW to retard or backwards CCW to advance so at the left pistons TDC (Flywheels LHI at 3 o clock flat mark) the points break open on the leading cam lobe and the rotor tip lines up with the caps leading tower, then 180 later, the same to the right plug on the lagging cam lobe and cap tower. Starting with the distributor at at max forward CW retard and stopping the flywheel at the left cylinders TDC and slowlyyyyy yyyyy advancing the distributor back CCW till that left plug wire (or plug) fires gets you awful close.
Post back any questions and let us know how it turns out, good luck n God Bless
John T
