5010 INJECTOR SIZE
MUD MASHER
01-30-2005 20:39:21
I'm CURRENTLY DEALING ON 2-5010's. THE OWNER TELLS ME THAT THE 2-TRACTORS HAVE DIFFERENT DIAMETER INJECTORS.HE STATES THAT THERE WAS A CHANGE IN SIZE PRIOR TO THE END OF THE SERIES.DO Y'ALL KNOW THE SERIAL NUMBER BREAK OFF HAND? IF I HAD A SERVICE/PARTS MANUAL I WOULDN'T BOTHER Y'ALL.
THANKS
MM
JDBert
01-31-2005 08:08:09
 Re: 5010 INJECTOR SIZE in reply to MUD MASHER, 01-30-2005 20:39:21
I'm with bob you seem to see quite a few 5010's with 5020 heads. I think the 5010 injectors are pretty pricey while the pencil injectors on the 5020 aren't to bad.
JDWayne
01-31-2005 06:35:18
According to PC # 803 from JD it says that the nozzles for the 5010 are AR36052 for American Bosch and AR36213 for Robert Bosch.
According to PC # 978 from JD it says for 5020 S/N below 024,999 it takes pencil nozzle number AR50782.
According to PC # 1156 from JD it says for 5020 S/N 025,000 and up it takes the same as above.It actually lists two different nozzles but they sub up to the number above. Hope this helps.
Bob
01-30-2005 20:55:53
My opinion, which is worth just what you've paid for it, is that ALL the 5010's had the large "Bosch-type" nozzles, and the change to the Roosa "pencil" nozzles came with the start of 5020 production.
JDPARTS shows one cylinder head fitting all 5010's, and shows 2 types of Bosch nozzles, American Bosch or Robert Bosch, with no serial number break, apparently used interchangeably.
Perhaps one of the 5010's has a 5020 head???
MUD MASHER
01-30-2005 21:14:18
 Re: 5010 INJECTOR SIZE in reply to Bob, 01-30-2005 20:55:53
WELL MY ONLY VISIT TO SEE THEM THE "THIN INJECTOR" ONE HAS A 5020 SERIAL NUMBER ON THE REAR-END. THE OWNER SAYS THAT IT IS A 5010 BUT ANOTHER REAR-END FROM A SALVAGE YARD WAS PLACED ON IT.I THINK IT'S A 5020 MYSELF AND I JUST WANTED TO CHECK.
THE REASON I'M PERSUING THIS UNIT,IT'S AN INDUSTRIAL IN AN AG TYPE STYLING(YELLOW),IT ALSO HAS THE INDUSTRIAL HOOD SIDE JD NAME PLATES AND YELLOW PAINT IN AREAS THAT ARE USUALLY NOT "ADDRESSED" WHEN REPAINTING.IT CURRENTLY IS WITH A POOR GREEN PAINT JOB WITH YELLOW AREAS THAT SHOW THROUGH.
ARE THERE ENGINE CODES OR INJ. PUMP #'s THAT CAN PROVE THIS ALSO?
THANKS
MM
buickanddeere
01-30-2005 23:43:14
 Re: 5010 INJECTOR SIZE in reply to MUD MASHER, 01-30-2005 21:14:18
Congratulations on finding that tractor.She's a rare machine.
Bob
01-30-2005 21:46:05
Sorry, I can't be of any more help, maybe Brandon from "Weird Deere" will chime in!
MUD MASHER
01-30-2005 22:10:52
 Re: 5010 INJECTOR SIZE in reply to Bob, 01-30-2005 21:46:05
ME AND BRANDON HAVE CONVERSED ON THIS INDUSTRIAL TOPIC.THE BIGGIE HERE WAS THE INJECTORS.
THANKS VERY MUCH,
MM
