49'B valve springs
BradAR
01-30-2005 18:09:27
had to replace two intake valves and face the head on my "B" that is in process of 'restoring' (getting to run) and also inserted 2 missing pushrod sleeves, but here's my question: how important is the valve spring pressure? I did not replace the springs . there was light rust on them that wire wheeled right off. Is this a potential weak area or realatively unimportant detail. (Springs were $22 each.) Also re-using the pushrods. Anything wrong with this? THanks
BradAR
01-31-2005 19:59:40
 Re: 49'B valve springs in reply to BradAR, 01-30-2005 18:09:27
I will check my book Mike, guess I just assumed that they were supposed to be there. Seems like the manual showed them . BHPapa, is the spring height the measurement of the spring length? if so , then I understand, if not , i am fuzzy. Again will check the book. I guess that leaving out the shims would make the springs even weaker due to the increased length? Thanks you guys , for straightening me out some.. BHP is my understanding correct?? BradAR
Mike M
01-31-2005 05:24:55
I'm wondering about those 2 missing push rod sleeves ? Are you sure they were missing ? Some of those B heads have 4, some (I think )only have 2, and I know that some of the later ones have none.
BushogPapa
01-30-2005 18:53:56
If there is no ruxt "Pitting" in them, they should be fine.. Spring-"Seat Pressure" is pretty low on the 2-Cylinder engines..be sure to use the appropriate spring shim to restore correct "spring Height" to at least have the original (close to it) spring pressure on the seat... Valve grinding drops the valve deeper into the head, and you need to compensate for that with shims... Ron.
