3020 3 point won't lift
robert mangus
01-30-2005 15:39:25
Hi,
We have a pre 100,000 serial number gas John Deere 3020. We recently replaced the hydraulic pump and dialed it up to about 2200 psi. Loader, brakes, steering,powershift all work. The rear hydraulic get 0 psi, and the 3 point won't work at all. The linkage seems to acuate the valve near the rockshaft cover. Is there a control valve or other hydraulic device that could be defective? Are the rear hydraulic and the 3 point issue related?
Thanks if you can help
Robert in Oklahoma
msb
01-31-2005 07:24:06
 Re: 3020 3 point won't lift in reply to robert mangus, 01-30-2005 15:39:25
Sounds like a priority valve problem.It is located under the hook directly at the rear of the hydraulic line coming from the hydraulic pump.Its function is to restrict oil flow to the hydraulics that are not functioning on your tractor to insure there is steering and brakes in case of low hydraulic pressure.If your loader is plumbed into the system before the proirity valve, that would explain why the loader works.Either the pump pressure is not adequate or the valve itself has a problem.Could the line from the pump have gotten dirt in it?
