45 Loader raised height
Randy G.
01-30-2005 13:39:43
I have a 45 loader on a "55 JD 50. Most the time it only raises just above the top of the front grille. If I hold the lift lever and race the engine it will slowly raise higher in jerky movements. The oil level is up. Is this tipical in colder weather or do I have other issues I should look in to? How high should it raise???
Mike M
01-30-2005 18:03:05
 Re: 45 Loader raised height in reply to Randy G., 01-30-2005 13:39:43
On a model 50 you will need a hose hooked to the front and the rear ports of the cylinders.These cylinders were only made with packing for one way operation the extra hose up front is to use the front of the cylinder for extra oil capacity. If yours is hooked up this way you may just need to get the air worked out of it and add extra oil.It should go at least 10 feet high.
sam in mo
01-30-2005 15:58:27
I just sold a loader like that off of my 520. It came off of a 50 and had a extra gal.resevior on it for the 50. It worked fine on the 520 with out the extra oil.
55 50
01-30-2005 15:34:10
The Operator's Manual for the loader says "Lift Height (To Heel of Bucket) 10 1/2 ft."
It doesn't say which tractor that it's mounted on as I expect that would make at least a small difference. The photo on the front of the manual shows a Model 620 tractor.
billde
01-30-2005 15:01:55
If I remember right it should lift to about 9 feet. You are probably running out of fluid. Try increasing the fluid level in one quart increments. Does it have 2 way clylinders or one way? It makes a big difference! If they are one way you may need an extra reservoir.
Randy Stoudt
01-30-2005 14:36:56
Those loader cylinders hold a lot of oil. Add another quart and see what happens.
I Bleed Green
01-30-2005 14:09:23
Maybe time for new oil. Old oil does not work good when its cold. I use John Deere Hy-gard in my 520. I have a 45 loader on it and with hy-gard my loader works good even when its very cold.
