730 Electric Start
DGK
01-30-2005 11:44:09
Put new batt. in 730 diesel electric start turned lights on and instantly blew them out. Has a fairly new 24v gen and regulator. No extra wires on batt. post. Thanks Doug
buickanddeere
01-30-2005 12:14:30
 Re: 730 Electric Start in reply to DGK, 01-30-2005 11:44:09
The batteries are connected wrong and are applying 24V between the switch and tractor chassis through the 12V lights. Or the battery mid point ground wire is missing/fuse blown. Not matter if using 2x12V or 4x6V batteries. At the middle connections, connect the ground wire to chassis. One "live" side of the batteries with the heavy cable supplies -12V to half the accessory loads. The other "live" side of the batteries with the heavy cable supplies the +12V half accessories. The generator,regulator and starter are 24V and cannot have any electrical path to chassis.
DGK
01-30-2005 18:14:26
 Re: 730 Electric Start in reply to buickanddeere, 01-30-2005 12:14:30
Thanks It is the ground wire mid way, I took the battery box off and hooked up the batt. to move tractor, no ground wire. Thanks Again DOUG
