45W on 70, question for FIT
SL
01-30-2005 11:11:30
FIT, I went through the archives and came across a post of yours with great advice on routing leaking oil from the air breathers on the 45W cylinders. You discussed how you have run the breathers into oil lines and join them together and then run that line into the oil system. I want to do the same.
Where did you link that main breather line back into the system? Some where on the return line I assume. I have a remote spool that controls my 45W with the pressure and return lines from the power trol going into that. Should I put my new breather line oil in the system between the spool and the power trol or can I join it external to the spool valve system so I can run shorter hose. Do I make any sense what so ever????
DP
01-30-2005 11:32:22
 Re: 45W on 70, question for FIT in reply to SL, 01-30-2005 11:11:30
SL, on my 45 loader I am running lines on both ends of the cylinders. It will also allow you to apply down pressure when needed. Been using this one that way now for close to 25 years with no problem. I think the hydraulics are the same on both loaders. Don
F-I-T
01-30-2005 12:37:22
 Re: 45W on 70, question for FIT in reply to DP, 01-30-2005 11:32:22
DP does it just like I do. In fact of the 45's we had over the years, I never knew that the front was really for tramp oil. We always just ran a pressure line to each.The front ones were for the "Down" pressure, and the rear ones were for lift. Now, because of the geometry of the loader frame, it's pretty hard to get enough down pressure to lift the front end up, especially on a 70D with power steering (pretty heavy on the front end) but it will lift it a bit.
I run the pressure line up to my 2x2 valve, and then a return line back to the return of the Powr-Trol. Then the valves direct pressure oil either to the front of the cylinder to lower or to the back to lift (same goes for the busket cylinders since I have hydro-tilt). Since the cylinders are completely filled with oil on both sides, the spare oil in the fronts helps it from leaking past the pistons, that is if it does, it has to go to the return lime and back to the sump. That way I seldom have to add make up oil. As long as my connections are tight, it's pretty closed.
Frank
SL
01-30-2005 18:23:09
 Re: 45W on 70, question for FIT in reply to F-I-T, 01-30-2005 12:37:22
Thanks guys, I got it I think. Maybe I will draw myself a diagram and float it out here for discussion...l
Mike M
01-30-2005 18:10:38
Hard to get a single V cup packing to hold pressure on the non V side. These only have single acting packing in the lift cylinders.
