1943 John Deer A
North Fork Ranc
02-15-2004 09:46:16
I have an old fly-wheel start John Deere A that my late father had-I think it is a 1943-I have used it for brush-hogging and occasional work for the last 15 years and it now is using oil quite a bit and fouling plugs extensively-still starts good with new or cleaned plugs but usually fouls them within an hour of working and starts hitting on only one cylinder---I'm no mechanic but I suspect it may need a ring job? Can anyone tell me if they agree with this assessment or offer any other explanation? ALso, if it is rings or whatever--how does one go about making the repairs and what might the costs be??
North Fork Rancher
02-15-2004 18:49:22
 Re: 1943 John Deer A in reply to North Fork Rancher, 02-15-2004 09:46:16
Thanks for the help--I use 30 weight oil--will try 40w with a new filter and will also try the Autolite 388-----Ones I've been using are Champion 12d (I think--can't remember for sure, as I'm not at the ranch right now--thanks again--) I see I can get a rebuild kit for $427.00.
Will P
02-15-2004 18:19:45
Give Autolite 388 plugs a try. Should help with the fouling.
Will P.
old
02-15-2004 14:59:15
First off what type of oil are you useing in it, if its say 10W-30 that isn't helping any. I'd round say a stright 40 weight oil in and see if it helps some, just a stop gap measure. Yes you probably need a rebuild on that old girl, cost if you have some one else do it will be $1000 or more depending on who and where
