If you really want to do this, and understand the split 24 Volt system well enough to do this, a Motorola 24 Volt alternator and regulator from a late 24 Volt 4020 will do the job. The 24 Volt system on these tractors is grounded in the middle, giving (+) 12 Volts and (-) 12 Volts. The "innards" of the alternator must have NO connection to the case for this system to work. You must specifically have the correct type of alternator, or your lights, fuel guage, etc. will not work. There are other sources for the correct 24 Volt alternator, a knowledgeable local rebuilder could probably help you out, but MOST 24 Volt alternators for trucks or industrial equipment use will have one side of the system grounded to the case, and are NOT what you are looking for.
Prices from Deere (There are other sources for the correct rebuilt alternators.): Deere re-man alternator TY1448 @ $140.00 Deere voltage regulator AR52928 @ 81.00
