JD 35 Loader
JDCRAWLERDOG
01-30-2005 05:25:54
Does anyone know who made the #35 Loader for John Deere? I am trying to find the 60" materials bucket for this loader and thought I might be able to cross JD"s part number (AC 12241C) with another supplier to expand the search. Thanks.
Dave in PA
11-22-2005 14:15:12
 Re: JD 35 Loader in reply to JDCRAWLERDOG, 01-30-2005 05:25:54
I saw a few posts about mounting a Deere 35 Loader on various tractors. I have a '53 40S and I just got a model 35 loader for it that was in great shape. The problem is that I got the mounts for a 435 diesel with the loader, which bolt to the back axle through 4 holes and won't work with my 40S. Does anyone know what the correct mounts look like and where they attach to on the 40s? Thanks!
Hayfarmer
01-30-2005 09:46:52
I was of the impression that JD made their own stuff, obviously buying hydraulic valves and so on. As for the materials bucket, mine has one but it isn"t a separate bucket completely. It uses the tines and back of the regular bucket. I think I would adapt one from another make of loader.
JDCRAWLERDOG
01-30-2005 14:23:54
 Re: JD 35 Loader in reply to Hayfarmer, 01-30-2005 09:46:52
I have the six tine manure bucket but I don't have the side sheets and bottom extention that you probably have on your bucket. The material bucket was a larger loader bucket than the six or seven tines manure bucket. You might be right about JD making this loader. I think I had heard somewhere that they may have been made by Montgomery.
Adapting another bucket is probably the way to go or find a set of the side sheets and bottom extension
Hayfarmer
01-30-2005 19:03:23
 Re: JD 35 Loader in reply to JDCRAWLERDOG, 01-30-2005 14:23:54
I don't know what tractor your #35 is on, but the bucket I have, adapted from the tine bucket, isn't especially strong. It is ok on my 430 but when I changed my #35 over to a hydraulic bucket from a trip type I beefed it up. The advantage is I can take out 4 pins(originally bolts) and drop off the extension and have tines. I also have the narrow adapter for the tine bucket to handle loose or sloppy namure. The only problem with the wide bucket on my 430 is that it is heavier, and since I don't have power steering it makes a distance. For this tractor it was ment for lighter stuff, not dirt. I put 3 or 4 hay bales on it to feed my cows each day and have used it gor hauling wood.
JDCRAWLERDOG
01-31-2005 10:17:46
 Re: JD 35 Loader in reply to Hayfarmer, 01-30-2005 19:03:23
My #35 is mounted on a 420W w/o PS. The loader has factory bucket hydraulics. The steering gets a bit stiff with a good size load. I can carry a light round bale, but I keep it close to the ground. I agree, the loader/420-430 combo has its limits. I am not looking for a large bucket.
