Check hyd oil level on 4010
Corky
01-29-2005 19:57:26
How do I check the hydraulic oil level on a john deere 4010?
Jarrod
01-30-2005 07:14:07
 Re: Check hyd oil level on 4010 in reply to Corky, 01-29-2005 19:57:26
Don't check your oil with all cylinders extended. That would only result in a mess. You want to check your oil will all cylinders retracted. If you check your oil with your cylinders extended you will find that your oil is low. So you are going to add and then when you retract your cylinders your case will be overfull. I saw a guy do this on a forklift and when he lowered the cylinder the reservoir overflowed and he had a mess. It all depends on weather you have a loader and how big the cylinders.
Bob
01-30-2005 11:12:47
 Re: Check hyd oil level on 4010 in reply to Jarrod, 01-30-2005 07:14:07
Jarrod, the whole transmission and rear case of the 4010 is the oil reservoir, and it holds 9 or 12 gallons. The return oil from a reasonably-sized cylinder retracting will have very little effect on that much oil volume. If the cylinder(s) are double-acting, the only difference between extended and retracted is the volume of oil displaced by the piston rod, so there would be even less variance in oil level.
txblu
01-31-2005 05:35:26
 Re: Check hyd oil level on 4010 in reply to Bob, 01-30-2005 11:12:47
That's a 10-4. Now on a different tractor it may be different, but not on these green ones.
Mark
Bob
01-29-2005 20:01:35
By uncrewing and removing the dipstick behind your right hoof.
txblu
01-30-2005 06:02:53
 Re: Check hyd oil level on 4010 in reply to Bob, 01-29-2005 20:01:35
Sits right above the landing you rest your "hooves" on and up against the hyd casting; knurled nut, 3/4 dia x 3/4 tall. Pull it , wipe it and stick it back. Pull out and look. Don't screw in to measure.....Same with engine oil.
When checking, all cylinders are supposed to be extended or whatever else to get the max fluid out of the chamber when assessing.
I do it the easy way. I just keep it filled about half inch above the mark (full) and never have any problems. Same as on the 4020. Seems when mine are just full, the pump takes time to prime and other things I don't need to tolerate.
Too full and I guess you'll be checking out your shaft/axle seals; know what I mean.
Mark
