48 D battery
Paul.D.Canada
02-15-2004 08:54:21
I have not recieved my manual yet, but would like to know if the "D" is positive ground or negative ground? Thanks in advance Paul.
Clooney
02-15-2004 16:28:38
 Re: 48 D battery in reply to Paul.D.Canada, 02-15-2004 08:54:21
Paul, the late D was 12 volt POSITIVE ground.. All the generator equipped 2-cylinder Deere's were positive ground.. Some of the later alternator equipped compact 2-cylinder Deere tractors were 12 volt negative ground though...
John T
02-15-2004 14:28:53
Paul, they came from the factory as POS ground as far as I know like all other 2 cyl Deeres, but many got changed over the years. They can be made to still charge and work regardless provided wired right and re polarized. Let us know if you have any questions or problems.
John T
JC
02-15-2004 11:09:35
Paul,
I have a wiring diagram {page 80-5-8} for a "D" that looks like it is a positive ground. I don't know if they changed polarity at some point. Mine is an unstyled "D" which has 'strongarm' manual start.
Where are u in Canada? I am in eastern Canada.
JC
Paul.D.Canada
02-16-2004 17:38:53
 Re: Re: 48 D battery in reply to JC, 02-15-2004 11:09:35
JC, I am located in southern Ontario.I'm about 20 min west of Niagara Falls.Nice to hear from some fellow Canadians.This is my second restoration, sold the other one before it was finished so I could build my house.Talk to you later Paul.
JC
02-16-2004 18:28:50
 Re: Re: Re: 48 D battery in reply to Paul.D.Canada, 02-16-2004 17:38:53
Hi Paul,
I'm just east of Ottawa. I met a collector a couple of years ago and got 'hooked'. I am finishing an unstyled D, I'm told it is one of the last 300 or so built in late 38' or early 39'. It was stuck so it's been a big project, but I've learned a lot!
Regards,
JC
Walt
02-15-2004 10:12:51
The Model D is Negative Ground.
old
02-15-2004 09:07:11
I believe it would have been pos. ground
Paul.D.Canada
02-15-2004 09:39:37
 Re: Re: 48 D battery in reply to old, 02-15-2004 09:07:11
Thanks Old, I misplaced your email address but I found it just after I posted this message. Thanks again Paul.
