Jeff, Check your linkage from the governor to the carburetor to make sure there is no binding anywhere that might have been introduced when removing/reinstalling the carburetor. If that is ok, your problems are symtomatic of blockage in the idle circuit. However, you should also check the fuel level in your bowl, or make sure your float is set properly. Your 430 should have a TSX 688 Marvel Schebler carb. Take the top off the carb, turn it upside down, and you will see a jet placed at an angle. This is the jet that feeds fuel from the bowl into the idle circuit. Try to remove the jet with a screwdriver that has a blade which gives a snug fit in the slot. If the jet does not come with a little turning, wash the carb out with soap and water to remove all traces of gasoline, and apply heat to the jet until there is a green trace. Let it cool until it feels cool, then it should back right out. Spray some carb cleaner in the hole and watch for it to come out in the slot near the throttle plate (and another, smaller hole near it as I recall - my diagrams are in the shop). This must be cleaned out for the idle circuit to operate properly. If you try to remove the jet with too much force you will bend the edges of the idle jet into the surrounding casting and make the job even harder. Then look at the bottom of the carb - you will find a hole that matches up with the idle jet - it leads down into the area surrounding the nozzle. Spray carb cleaner into that area to make sure fuel can get to the idle jet. You may have to remove the nozzle - an earlier post described how to do that. The tractor operates off the idle circuit at low throttle, and mostly off the idle circuit at high no-load throttle. If the circuit is plugged, fuel is not present and as the engine slows down the throttle plate opens and air flows in the venturi over the nozzle and "gulps" fuel from the load circuit. The engine speeds up until that fuel is gone, slows back down, and the process repeats itself. When the idle circuit is operating properly the throttle plate stays nearly closed and fuel comes through the slot in the throat near the throttle plate.
