Electrical changes to a 1958 JD720 diesel
Freddy
01-29-2005 15:29:51
Has anyone successfully changed a 6 volt 720 diesel with pony start to 12 volts? Would really like to go to an alternator and 12 volt battery. We have changed a lot of 6 volt gas tractors to 12 volts. the starters are tough enough. Just get your finger off the starter button if it doesn't start right away. Even changed out a JD 45 combine to 12 volts. Our VAC case was the first, still going stong on the first starter 20 years later.
randy hall
01-29-2005 17:09:24
 Re: Electrical changes to a 1958 JD720 diesel in reply to Freddy, 01-29-2005 15:29:51
i changed my 720d to twelve volts around ten years ago.i wanted to use 100 watt halogen lights to be able to see to plant with, because six volt lights are about as bright as a candle. i used a twelve volt generator and regulator and put a twelve to six volt resister in the line to the coils. the fuel gauge still works fine even tho everyone will tell you that it won't.
01-30-2005 12:30:59
 Re: Electrical changes to a 1958 JD720 diesel in reply to randy hall, 01-29-2005 17:09:24
Forgot something. The starting bypass circuit cannot be allowed to feed the cranking engine ignition coils full 12V system voltage direct while cranking.
buickanddeere
01-30-2005 12:28:47
With that 12-6 dropping resisitor, should just one cranking engine set of points be closed. And the ignition switch left on, that one coil will smoke in several seconds instead of in a minute or two.
Freddy
01-29-2005 20:06:59
Thanks for the info. I'll start on it
