Check / Replace Oil in 1949 Model A
Kyle Anderson
01-29-2005 13:50:43
Hey guys, My '49 Model A is blowing fuel out of the exhaust and it is also leaking from around the clutch drum. I believe that the fuel ran completely throught the carb (had a bad carb recently) and just pooled in the case. I dont want to run until I completely drain and replace any oil that I need to. Which brings me to my questions. Where do I check the level and which plug/s do I remove to drian? How do I refill? And with what type of oil?
I know I am asking really trivial questions, but I just acquired this machine and I really want to learn everything I can before I go tinkering. Thanks for any help!!
Mike M
01-31-2005 06:54:33
 Re: Check / Replace Oil in 1949 Model A in reply to Kyle Anderson, 01-29-2005 13:50:43
It's always a good idea to shut of the gas at the fuel bowl when you let these sit. Even with a good carb. something could make it stick and it's all down hill until it fills up your engine.
Pappy
01-29-2005 14:55:08
Yep!--you got it figured out. Don"t try to start it until you get all the gasoline out of the crankcase.
To check the oil level, open the plug just below the clutch pulley. This plug sticks out about one inch from the tractor. 3/4 inch, i think. Just loosen it to see if the crankcase is full, or you can remove it to let any excess run out. To drain the oil, remove the plug on the bottom of the engine. It is a pipe plug. Also, remove the big oil filter cover, about 4 inches in diameter, and remove the filter. Get a new filter at NAPA or your friendly JD Dealer. When replacing the filter, do not overtighten the big nut and cover. Replace the filter cover gasket if you can get one. Some filters come with the gasket. To refill the engine, the fill plug is just above the clutch pulley. It is a 1.5 inch pipe with a screw on cap. The engine will hold 12 quarts of oil, with a new filter. I use 10W30 in mine since it is in cooler climate. If you live in hot climate, I would use 15W40. Post back if you have additional questions. Have Fun!
Kyle Anderson
01-30-2005 16:56:20
 Re: Check / Replace Oil in 1949 Model A in reply to Pappy, 01-29-2005 14:55:08
Thanks alot! I did what you suggested and it is running much better now. I need to adjust my carb for better performance, but at least I know I have clean oil. I am glad that I replaced it too. What came out was about 80% gasoline and 20% oil. VERY thin and VERY black.
Again, thank you!
