1946/1948 John Derre A Serial Number
Michael P. Desl
01-29-2005 12:48:02
I just bought a tractor at an auction. The Auctioneer said it was a 1948 John Deere A, someone at the auction (bidding against me) said it was a 1946. I have no idea, so I wanted to look up the serial number, but I can't find it. Where is the serial number located on a 1946/1948 A?
I went around the tractor and got several numbers that looked relevent off of the castings; A2644R, A2468R and A2217R, but none of them appears to be a serial number.
Any help would be appreciated.
---Mike
fixerupper
01-29-2005 14:41:45
 Re: 1946/1948 John Derre A Serial Number in reply to Michael P. Deslippe, 01-29-2005 12:48:02
Someone help me on this, but I think the '46 has a flat cast frame and open faced flywheel where the '48 has the stamped steel frame and totaly enclosed flywheel. Geez, I'm trying to find a picture of a '46 but haven't had any luck.
Dixieland
01-29-2005 16:28:37
 Re: 1946/1948 John Derre A Serial Number in reply to fixerupper, 01-29-2005 14:41:45
I think the first JD A stamped steel frame was made in 1947. I have a 1946 JD A indicated by the serial number. The flywheel has a shroud around it and has the angle iron frame. Also, the starter is on top of the crankcase.
CMB
01-29-2005 15:34:14
A '46 "A" would have an angle iron frame. Cast "front supports" were only used during WW2 when angle iron was not available. I believe the serial # plate on this vintage would be sort of under the Magneto, or Distributor if so equipped.
greenmech
01-29-2005 14:56:19
The 46 A should have a cast frame and open flywheel. Ron Mn
David from Kansas
01-29-2005 13:22:45
Mike, there should be a separate small serial number metal tag riveted to the main case of the tractor near (in front of) the belt/clutch pulley. I don't remember if it is on the top or side of the main case. Someone correct me if I'm wrong.
David
Michael P. Deslippe
01-29-2005 15:50:39
 Re: 1946/1948 John Derre A Serial Number in reply to David from Kansas, 01-29-2005 13:22:45
Bingo! As you might expect, it had been painted over thoroughly. Some paint stripper and a wire brush revealed they were both wrong (which figures). The Serial Number was 527217 which is a 1943.
Thanks for the help.
---Mike
Pappy
01-29-2005 15:01:34
The tag should be on top of the case, close to the magneto/distributor.
