1946 b clutch help!!!!!!!
frank chop
01-29-2005 11:09:10
i posted a question about the clutch facings and also need to know if i need to pour oil into thefirst reduction gear cover. please respond i need help with this final assembly.appreciate any responses.
Mike M
01-30-2005 05:58:36
 Re: 1946 b clutch help!!!!!!! in reply to frank chop, 01-29-2005 11:09:10
If you had that first reduction cover off you will need to add some engine oil in there. The later B's had a drain and fill plug in them so you could change it when you did the engine oil changes. I have drilled and tapped most of my older tractor covers when I had them off so I could change this oil.
greenmech
01-29-2005 14:24:56
You do not need to add oil to the first reduction cover.According to the IT manual the rounded edge of the innermost disc should face inward. The rounded edge of the outermost disc should face outward. Hope this helps. Ron Mn.
