46 B carb problems
Fredf
01-29-2005 07:27:13
I recently purchased a 46 B. I was able to free up the stuck motor and get it to run. the carb was really in bad shape. I sent it to a local rebuilder and purchased two different brands of basic rebuild kits. When I got it back and put it on he tractor, the tractor started up without a problem but I can"t get to idle properly. The idle djustment screw doesn"t have any effect screwed in or out. The load screw seems to work. The engine seems to pulse. Any suggestions?
John T
01-29-2005 08:45:27
 Re: 46 B carb problems in reply to Fredf, 01-29-2005 07:27:13
Fred, To set her roughly, turn the idle screw in closed then back out about 2 turns n see if it still makes no difference???
Its possible one or more of the cabs internal idle circuits (some located behind brass drill plugs) are clogged up. If it was rebuilt CORRECT all those brass drill plugs should have been removed (usually requires heat) and the idle circuits behind them drilled out using the correct sized No. 40 and No. 53 long aircraft drill bits (DONT drill too deep and use correct sizes in those correct holes ONLY) plus the other smaller idle passages cleaned using steel guitar strings or welding wire etc. In the event those were plugged, cleaning n soaking n boiling till the cows come home WILL NOT DO THE JOB. Take a look at
Link
PRELIMINARY CHECKS
1) See if some choke will make her idle better??? If so, the carbs idle circuits (those behind drill plugs and/or other smaller ones) may be plugged (see above) and/or she may have a vacuum leak which leans the mixture.
2) CHECK FOR VACUUM LEAKS: Spray/direct an unlit propane torch or Carb Cleaner or WD 40 etc around the carb and its throttle shaft and junction to manifold and manifold base, and if she speeds up or smooths, you may just have a vacuum leak WHICH CAUSES POOR IDLE.
3) See if you can idle her smooth by removing the throttle rod and manually idling her?? If she idles slow n smooth there BUT NOT VIA THE GOVERNOR, you may partly have a governor or linkage problem. Insure the linkages are free and theres no cotter keys or wires etc. binding up any of the rods and junctions etc., especially where the rod enters the carb.
4) If it has the horizontal idle stop screw, see if its bumping up against the vertical stop spring?? It should be bumping up against n stopping there at a good slow idle.
FINALLY,,,,, ,,if theres no vacuum leaks,,,,, ,,if adjustign the carb or manually throttling it still dont help,,,,, ,,,if the throttle rods not binding anywhere,,,,, ,,,,and ESPECIALLY if a lil choking does help,,,,, ,,,and at idle (despite adjustments) she surges up n down up n down and cycles (caused by governor action working)
I SUSPECT SHE HAS AN INTERNAL IDLE CRCUIT (behind the drill plugs or elsewhere) PLUGGED.
If so it may require the use of heat to remove the brass plugs and use the drill bits as noted above to properly clean the internal idle circuits.
Let us know, Good Luck n God Bless
John T
Fredf
01-30-2005 08:25:51
 Re: 46 B carb problems in reply to John T, 01-29-2005 08:45:27
John T, thank you for your response. I'm positive that they didn't clean all of the tiny passages when they rebuilt the carb. I guess I should have bitten the bullet and sent my carb to Roberts in the first place. I'm going to replace the corroded all-fuel manifold with a gas manifold. I'm not going to make a show tractor out of it, just a good looking fun tractor, so it doesn't have to be 100% correct. Just hearing it putt right now has got me inspired, so when its running right it should be a lot of fun. Thanks again for your help. Gob bless you and your family, Fred
