Emerald, Im not smart enough to tell by lookin either, but have a few things that may help in the general correct fuel gauge department. The MOST important consideration on float type variable resistance senders n fuel gauges is THAT THE SENDER BE CORRECT FOR THE GAUGE, regardless if it were on a 6 or 12 volt tractor. Some of the senders were in the 0 to 35 ohms range, while others may be upwards and over 100 ohms or more. The gauge is more a current sensitive than a voltage related device, however, if it and its sender are for a 6 volt tractor, it wont be correct if used on a 12 or vice versa. I have done a lil ballast resistance addition in my life to make one work n match voltages n senders etc., but its not any exact science or what I would reccomend in public anywhow lol. It might help to know what voltage the tractor was originally, maybe by tracing it via its Serial Number, and then get a gauge n sender to match?? If one had the exact engineering specs of the gauge n sender resistance values etc he might take some readings n see if it were originally on a 6 or 12 volt system, but whos got that?? Not meeeee e, Duane n Cloney have some good Delco and Wico Specs n data, but I doubt if anyone here has any fuel gauge n sender specs. Finally, theres always the experimental method. If you have the gauge and a matched good working sender, start FIRST by hooking them up to 6 volts, raise n lower the float to max full n empty, n see what the gauge does at each extreme????? If its accurate and has good slow even needle deflections (not real fast or it pegs the meter), it must be a matched set and intended for 6 volts, HOWEVER, if not, you could next try it at 12 volts, but I would use caution on the zero resistance part of the sender and lightly and very quickly/momentarily just tap the last connection in case the meter is drawing too much current and quickly pegs or swings too rapid, if so, it might be for a 6 volt configuration would be my guess. Sorry no answer, let us know how it turns out, Good Luck n God Bless John T
