Front loader for JD B?
Tom Scott
01-28-2005 16:59:59
Just curious. Did John Deere have a front loader bucket for a model B tractor? I see a lot of Bs for sale, but I don't remember ever seeing a B with loader. Not in the market today, but someday would like to get an old B and restore it.
55 50
01-29-2005 21:38:06
 Re: Front loader for JD B? in reply to Tom Scott, 01-28-2005 16:59:59
Are you planning this for real use or just as a restoration project? You will find that any tractor with hand clutch is not much good as a loader tractor since you really need 3 hands to be efficient. Good loader tractors have foot clutch, live hydraulics, power steering, and if it's winter, a cab. A John Deere "B" doesn't have any of those features if its a regular "B" that hasn't been modifed.
ChuckW
01-29-2005 05:50:11
Per the previous post, a loader on the B's may be somewhat of an after thought. The main drawback is lack of ample hydraulics. You will need a lot of modification/auxiliary pump(maybe) oil reservoir/ie. The later models 50's on up had a live pump with ample pressure. Also you'll need the 3rd arm to operate(the hand clutch problem). I wouldn't say to not do the project but I would say to be ready to make some majory changes to your tractor with some significant expense.
F-I-T
01-28-2005 17:12:06
The 45 loader would fir a "B", and I think the '50' loader would, too. The "B" is a biut light to do any harsh loader work, but then that keeps you from messing up the loader, too.
Frank
Randy Stoudt
01-28-2005 18:01:22
 Re: Front loader for JD B? in reply to F-I-T, 01-28-2005 17:12:06
I agree that a 45 loader would be a good choice. I just bought a nice one with no weld repairs and a snow bucket from a local equipment dealer for $300. I have seen them go for less on Ebay. Add a govenor driven live hydralic pump and you will have a nice set up. To keep it safe put your rear wheels as far out on the axles as you can and add weights.
Tom Scott
01-28-2005 18:05:27
 Re: Front loader for JD B? in reply to Randy Stoudt, 01-28-2005 18:01:22
In a related question, did they make a B with wide-spaced front wheels (which would make it more stable with a loader), or were they always set in a V in the center?
CMB
01-29-2005 15:39:16
 Re: Front loader for JD B? in reply to Tom Scott, 01-28-2005 18:05:27
In actuality a wide front adds nothing to stability, that's only an illusion. It could make it ride a little better, & not sink into the ground quite as easily with heavy front end loads such as a loader.
RayP(MI)
01-28-2005 18:40:15
third party image
Yes, they did make WFE on B's. We have a New Idea-Horn loader for ouur '49 B. Looks ungainly as the dickens but works well, lifts tremendous loads, and will reach suprisingly high. Our problem, is that we need an auxillary oil reservoir, which is mounted behind the seat. Oil keeps leaking out of rocker arms. Other problem is that hydraulic pump only operates when clutch is engaged, (along with PTO), so you're constantly putting it in neutral while engaging clutch to lift loads. Uncle had a dandy loader on his 50 which had the two arms back to rear axles and the cylinder in front of the pedistal in front of the tractor. Couple of cables ran over pulleys at top of cylinder to lift the loader. Worked great on the 50 which also had live hydraulics.
old bones
01-29-2005 19:21:51
 Re: Front loader for JD B? in reply to RayP(MI), 01-28-2005 18:40:15
had a horn loader like yours on my 48B, then put it on my 49A. mine had single stage cylinders, though, and yours has 2 stage. on my B, there was enough hyd pump to lift a back tire off the ground with a full bucket of wet, heavy snow. likewise, i had to put an aux oil tank behind the seat. contrary to one of the above posts, it shouldn't cost him more that $25 or $30 to find a tank suitable to use as a reservoir and plumb it in. old bones
Tom Scott
01-29-2005 11:35:06
I would love to see more detailed pictures of that loader. Maybe against a sky background and some closeups of the functional details. It looks pretty interesting.
I think I have a new goal, a B with WFE and a FEL!
