3020 powershift stuck in forward+reverse
Jason(ma)
01-28-2005 14:45:35
has anyone run into this one? Start to move forward goes a few feet then binds up, pump howls and stalls motor out. reverse does the same. 3pt + power steering work fine. Sitting still will run for 20 sec or so and then stall out. Tow/haul engaged and it still stalls out. if you keep moving the shifter from forward to reverse and back it'll stay running until you stop moving the lever, then howls and stall. I pulled the trans control unit (can't remember the correct name at the moment) only thing I found was a slight pucker to the metal gasket at one of the outer bolt holes. Any ideas?
msb
01-28-2005 17:29:40
 Re: 3020 powershift stuck in forward+reverse in reply to Jason(ma), 01-28-2005 14:45:35
Just a guess,but I would suspect the gasket in the clutch pack has blown and is trying to engauge two gears at once.The maniflod gasket is in the front of the clutch pack.Saw one go bad about 35 years ago ,but can't remember how the transmission acted.
"trans control unit" =shift valve or shift valve housing
