2010 starting problems
Bill in SWIowa
01-28-2005 11:49:03
My 1963 gas 2010 will not start. It will begin to fire and start then as soon as I back off the key it dies. If I keep cranking it will stay running until I let off the key. I don't know much about mechanics so any help would be appreciated.
John T
01-28-2005 12:47:47
 Re: 2010 starting problems in reply to Bill in SWIowa, 01-28-2005 11:49:03
Bill, I dont know a 2010 from beans, but in the event those tractors have a ballast resistor like the old 2 bangers with a ballast by pass starting system which applies hot battery voltage to the coil (or low output side of the Ballast) ONLY WHILE CRANKING (thus by passing the ballast) I would swear EITHER (A) the Ballast is bad/open OR else (B) Theres a problem in the switch.
(A) If you turn the key on THERE MUST BE VOLTAGE on the coils high input (NOT to distributor) terminal !!!!! Does yours read voltage there with the key ON ??? If not and it has an ignition ballast resistor, I suspect its bad/open. If thats the case BUT VOLTAGE DOES APPEAR THERE WHILE CRANKING, I again suspect an open/bad ballast resistor.
(B) NEXT: If it has a ballast or not, STILL when the switch is on if its good??? its IGN output terminal which leads to the ignition (coil or ballast) MUST READ HOT. If not, the switch is bad or its missing any hot battery feed due to a bad wire or blown fuse etc. See if the switch has a BAT or main voltage input terminal, and if its ALWAYS HOT. If so but theres no voltage on its IGN output down to the coil or ballast, the switch is bad.
NOW, the older ballast were the white ceramic bathtub type about 1/2 x 1/2 x 3 inches or so and they have to be loacated in the Ignition circuit BETWEEN the switches IGN output terminal and the coils high input (NOT to distributor) terminal. ORRRRR RR they may be made of resistive wire (if the tractor even has one) like a wire or fusible link looking wire or a springy coil looking thing on or near the switch.
Typical ohms values of a ballast resistor are in the 1.25 to 2 ihms range, so if you find one and its an open circuit, its baddddd dd.
Finally,
(A) Just stick a test lamp or a voltmeter on the coils high input (NOT to distributor) terminal and turn on the key AND VOLTAGE MUST APPEAR. If not but it DOES APPEAR while cranking the engine, look for a bad/open ballast resistor or resistive ballast wire or it may even have a springy coil looking resistir on the switch or in line between it and the coil IF IT HAS A BALLAST ???
or
(B) If it has no ballast or by pass system, with the switches IGN output leading to the coils high side, then place a test lamp or voltmeter on the switches IGN (to coil) terminal turn her on and VOLTAGE MUST APPEAR or the switch is bad or its not getting any hot battery voltage feed caused by a bad open circuit or blown fuse etc.
Hopefully someone who knows 2010"s or has a wiring diagram can help out n let us know if it even has a ballast, and if so, where its located and what type it is??? Otherwise until then, I have to suspect a bad switch (NO hot feed when ON out its IGN terminal) or a bad/open ballast or its associated wiring if it has one.
Let us know, good luck n God Bless
John T in Indiana
jdemaris
01-28-2005 13:40:46
 Re: 2010 starting problems in reply to John T, 01-28-2005 12:47:47
2010 uses a 12 volt system with a 6 volt coil. Original ballast resistor was the "increased resistance with heat" type as I recall - but I'm not sure. Deere gives little specific data on the subject. When new, the resistor was built into the ignition switch and the switch provided the cranking 12 volt bypass. Then later, Deere came out with a change-over kit to put a separate resistor in that is separate from the key switch. I believe the replacement resistor is NOT the "increased resistance with heat" type, but rather a constant resistance. I like the former type better that offers little to no resistance at first, but as it heats up resistance increases - like many Ford tractors use with no bypass needed. But, they DO tend to burn out, especially if the key is left on without the engine running and the points are closed. That's what happened with many of the original Deere switches with the built-in resistors. I suggest to the owner to put a jumper straight from a known 12 volt source to the coil primary and try starting it that way. The 2010s came with Delco or Prestolite starters. If it has the Delco, a bypass wire can be hooked to the built-in bypass in the Delco solenoid - maked R. My experience with the later Deere gas engines that use 6 volt coils with 12 volt systems is - stick with the 6 volt coil as designed. We put a lot of 12 volt coils on these tractors and they did NOT seem to start as well in cold weather. Voltage at cranking with a 12 volt system is usually around 9 volts, and for some reason, Deere figured a 12 volt coil did not offer enough spark at 9 volts for cold weather starting. Works in other makes of tractors okay - I don't have a good answer for that.
HTR
01-28-2005 18:10:44
 Re: 2010 starting problems in reply to jdemaris, 01-28-2005 13:40:46
Yep, it goes back a long time, and it is hard to remember it all. At one point the pink wire from the ign. switch to the coil, was a resistor wire. When you got a new coil you got a wireing harness with a pink nonresistor wire, and a white bypass wire that went to the solenoid. For a while it seemd every time you ordered a coil, or switch, you got some different change over. If the pink resistor wire was left in the harness, and the ceramic housed resistor was installed, you had double resistance. Have seen it happen, but they would run, if you ever got them warmed up.
John T
01-28-2005 13:53:36
Thanks for the good details, I didnt know if or how Deere did it later. Sounds like then, he could still have a "bad ballast" be it an internal switch or an external type. I guess if its still an internal switch component, he needs a new switch, but if he has the external, he may get by with just a new ballast. REGARDLESS, hes gotta have voltage to his coil when ON but if not,,,,, ,,,,, test the switch first to see if its got voltage on an IGN output terminal when ON,,,,, ,,,,, and if so, test next at the coil,,,,, ,,,,, , but if no voltage there, look for an in line series ballast of some sort.
Mkae sense to ya????? ??/
John T
jdemaris
01-28-2005 18:48:00
 Re: 2010 starting problems in reply to John T, 01-28-2005 13:53:36
What you say make perfect sense - but - I think there are somewhat unique problems with some of the later gas engine Deeres. With this 2010 - I don't know the history. If it usually starts fine in cold weather, and now - all of a sudden has these new symptoms - then it's logical to assume a resistor problem. But, if he's a new owner and has no previous experience with cold starting with this tractor - it might be a different story. Could very easily have the wrong coil on it. Easy to assume a 12 volt system gets a 12 volt coil - not a 6 like it's supposed to have. I was a mechanic for a Deere dealer when some of the 1010s and 2010s were new. We had a miserable time with them burning out ignition points - and we suspected the problem was the 12 volts systems on 6 volt coils causing excessive point arcing. That's why we changed quite a few over to 12 volt coils. Doing that DID make the points last longer, but then we encountered cold starting problems. I won't go into all the boring details, but we would take a matching coil and resistor from a good starting tractor of a different make (not a Deere), install it on one of these Deeres, and we'd have cold starting problems. I own one, a 1960 1010 crawler. I have a Delco 12 volt coil and matching resistor with a starter solenoid bypass. The original coil was burnt up in a fire, and I got lazy and bought a new 12 volt coil at NAPA. I usually never use the crawler in the winter, so I was not concerned. I went out to start it last week in 5 degree F. weather - it wanted to start - almost - when cranking, but would die when the key came back to run position. The coil was getting a full 9 volts at cranking, but it was not enough for good starting. I was moving equipment, and my 1964 Ford 4000 started right up, so did my Case VAC with 6 volt system, and so did my Cletrac HG with magneto. And, the engine in the 1010 is all new. Now, of course there are other variables and possibilities here. When I worked for Deere, we asked for more detailed information about this particular igntion system, but never got any specs. from Deere. The shop manual give almost nothing - no resistance values, coil output values, or anything, doesn't even mention the fact the the coil is 6 volts. I believe Deere used the system with all the later gas engines. I had the same sort of problem with a gas 2020 I used to have - it too calls for a 6 volt coil. So, it's one of those things I guess. I've always suspected there is some mechanical reason why these later Deere gas engines require a higher than average spark intensity or voltage to fire up in cold weather - and it seems Deere felt the same way. I never has such problems with the old Deere two cylinder tractors.
