5010 industrial
thejdman01
01-28-2005 11:20:42
local gravel pit closed awhile back they got everything they could out of her and to make a long story short they reclaimed the land and now the land is sold. ive known the owner of the pit as long as ive been alive. he called me because he knew i was a big jd fan and "collector" (i have alot of old ones i picked up very cheap that one day ill get around to restoring its just my showroom (all the junk outback). anyways he called and said that he had an 1963 5010 jd on a turapolt wanted to know if id have a home for it or know of someone who would want it as the land was sold and they were cleaning up and it had to get out of there. the story of the machine was that the motor lost coolant while the operator was on lunch and left it running and motor seized. they just kept it around to take the top layer of dirt off to get the gravel and needed it and it seized so they drug it off to the side and never got around to rebuilding it and they went and got another one. i told him i might know of a home had to call around came home ran the serial number on machinery link.com said rough price was 4,000 dollars but around here i know youd be very hard pressed to get atht much out of it but i saw the weight of the tractor alone was 13,200 lbs. the turnapolt has to weight at least 10,000 lbs at least so i know theres at least 11 tons of steel there. i figured steel price if i jsut junked it would be 500 bucks and he asked me to tell him what id give for it what i thought it was worth and i figured id start low and i lowballed him at 500 bucks and to my shock he took it. i loaded itup and brought it home. it is still on the trailer. my question is i cannot find any production numbers on the internet for 5010 i's and i cannot find many 5010i's on the internet w/turnapolts to get a rough idea of what its worth restored. i dont know that there is a market for it around here running to be put into service. i dont know of anyone that would restore it to keep it. so i was thinking about restoring the tractorand scraping the rest but i have no clue what i would use the tracor for and would have no clue what it is worth restored. i dont know of any market for one around here and dont knwo how much of a collectors item it is does anyone have any insite as to probably the best use? restore it myself, get rid of it just get rid of the turnapolt and keep the tractor any clue what one running and gone through and i mean gone trhough (clutch bearings in rear end total motor overhaul) is worth? anyone know production numbers and that the turnapolt weighs? thanks
Roy Suomi
01-29-2005 05:21:10
 Re: 5010 industrial in reply to thejdman01, 01-28-2005 11:20:42
Unless you're a diehard 5010 guy and you absolutely have to have this heavy old piece, I would just scrap it out. There is a market for used parts. Transmissions go for around $ 2000.00. If you salvage out this tractor be sure to follow service manual to a "T" with transmission removal. There is a spool that has to be removed before seperation. I found this out the hard way years ago.. Cost 350.00 out of my pocket...I think you can make out well if you list on E-Bay. there are a lot of people looking for used parts as opposed to new
thejdman01
01-28-2005 18:04:01
i have no way of posting pictures i dont knwo capacity or make. it does look jsut liek the link that was posted
Ken in Mich
01-28-2005 17:40:55
Here is some info:
DMont
01-28-2005 15:11:26
What is the brand of the pull scraper, cubic yards capacity, and how much is it worth. Any pics?
JDBert
01-28-2005 11:31:58
Check on www.weirddeere.com good site that will probably answer all your ?'s.
