JD 46 Loader - No Float
JD in KS
01-28-2005 11:00:15
I have a JD 46 Loader plumbed direct to my 3020 but the loader doesn"t have a float position. Can I add "Float" without replacing the valve?
Thanks in advance.
msb
01-28-2005 17:41:47
 Re: JD 46 Loader - No Float in reply to JD in KS, 01-28-2005 11:00:15
I assume your 3020 is not a side console model.The float can be attained in your valve by simply changing the operating lever from the hole it is now in to the other hole in the lever on the selective control box.A little tip.Remove the top E clip and the the lever will drop down where removing the bottom E clip is removed a lot easier.Reinstall the same way.Yes, you will have to remove the hood to get to the darned thing.
John36bn
01-28-2005 15:02:36
By "plumbed direct" I`m assuming you mean plumbed thru your remote couplers. Some of those remotes could give you float position by changing the position of a cover plate. That should be covered in your operators manual.
