Removal of broken front end support eyebolt AR/AO
better_dead_than_red
01-27-2005 14:10:54
Anyone ever have to get one of these things out? It is broken off below the surface of the casting. I have drilled a centered 1/4" hole through the entire stud (which is at least 2" in depth). If it was steel I would blow it out with a cutting torch but it appears to be cast iron.
Dave in Ohio
01-28-2005 16:42:34
 Re: Removal of broken front end support eyebolt AR in reply to better_dead_than_red, 01-27-2005 14:10:54
I drilled mine with a 7/8 drill. Put a little heat to it and backed it with an easyout. Had that darn big easyout for years and finally found something to do with it. I replaced it with the round eye of the lift arm of an old cultivator. Just built it up with weld and turned it down and threaded it. It is cast steel not cast iron.
Deere-Tom
01-27-2005 16:52:38
The eyebolt on my BR was broke off much the same as your AR but some one had tried to torch it out I do not know what it is made of but they made a mess of it. I had to cut it out with a die grinder and a carbide bit,then chase the threads.
F-I-T
01-27-2005 15:40:57
BDTR:
I would seriously doubt that that eye bolt is cast iron. I suspect that at worst it is cast steel, and even then I'd be surprised if is not forged. A cast iron eye bolt there would not have been of much value for its intended purpose.
Frank
