Hyd cylinders on a JD-60 what are they for??
old
01-27-2005 11:01:24
I have a JD-60 that I'm parting out and it has 2-two stage hyd cylinders on it. These cylinders are about 4 foot long closed and 8 feet long open. The problem is thats all that is there other then the mount for them that is under the belly. So what in the world where they for, I would think if it where for a loader it would have lifted up to the moon so to speak. So any body have any ideas???
Thanks
willie j
01-28-2005 04:53:19
 Re: Hyd cylinders on a JD-60 what are they for?? in reply to old, 01-27-2005 11:01:24
Old
I agree, they look like New Idea/Horn loader. A strap iron connected from the hole at top to lift arms near bucket. Lift arms connect to a bracket on rear axle housing. A popular unit in my neighborhood back in the 50's. Lift arms could be straight for use on narrow fronts, a curved arm avail for use on wide fronts.
HTH
Willie J
old bones
01-27-2005 16:17:04
like said below, they are from a horn loader, and there were at least 2 versions- single stage and 2 stage. these are 2 stage, where the cylinder will come out with 2 telescoping rams versus just 1 with single stage. used to have one. took a lot of hydraulic oil to lift, but would lift an M1A1 tank.
old bones
bruddies pop
01-27-2005 15:08:28
Those are New idea Horn loader cylinders. I have a couple laying around that are identical.
ChuckW
01-27-2005 13:29:29
the tractor loader cylinders are usually mounted on the uprights at the axles. This sure is a different fish. Maybe its a home rig item. Doesn't look very sturdy as load is hanging on a couple of bolts to the side of frame. I wouldn't want to trust it with much pressure.
JDBert
01-27-2005 13:02:25
Those look like whats left of a old vaughn or horn loader. the cylinders pushed straight up and had either a pulley for a cable that lifted the loader or the later ones had steel straps.
Mike M
01-27-2005 11:47:22
It could be cyl's for the #45 loader. Are they bolted together with the bolts showing the whole length ? That loader had cyl's about that long.
old
01-27-2005 11:55:06
 Re: Hyd cylinders on a JD-60 what are they for?? in reply to Mike M, 01-27-2005 11:47:22
I'm posting a picture of them right now in parts and pieces
RayP(MI)
01-27-2005 18:23:57
 Re: Hyd cylinders on a JD-60 what are they for?? in reply to old, 01-27-2005 11:55:06
Got ones just like that on the New Idea-Horn loader that came with our '49 JD B.
Mike M
01-27-2005 12:45:59
I sure don't think those are anything JD. Might be off a Farmhand or some other brand loader or hay stacker.
